New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
theer |
Nov 6 2018, 05:24 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
What do you guys think? Am I in over my head? (IMG:style_emoticons/default/welcome.png) I had to look up what a 4A-GE blacktop is, but you're definitely not in over your head. 914's have been swapped with many different motors, so an easier route would be to copy what's been done already.. but that's totally up to you. Fix it up and drive it first is a great idea, though. You'll get tired of the T4 soon enough, but will love the handling, etc. Good luck! |
betz |
Nov 6 2018, 06:19 PM
I had to look up what a 4A-GE blacktop is, but you're definitely not in over your head. 914's have been swapped with many different motors, so an easier route would be to copy what's been done already.. but that's totally up to you. Fix it up and drive it first is a great idea, though. You'll get tired of the T4 soon enough, but will love the handling, etc. Good luck! Thanks for all of the welcomes! I hardly got that on r3vlimited, haha. The 4A-GE is a Yamaha designed Toyota motor made famous by the anime initial D. It's found in the AE86 corolla and the original MR2. The blacktop is the final iteration of the motor, found in some JDM only FWD corollas from the late 90s. It's a 1.6L I4 making 160 hp. Redline is at 8300. 5 valves per cylinder. 11:1 compression. Comes stock with individual throttle bodies and runs off a MAP sensor. This makes fitting it with open air trumpets a bolt on affair. It might just be the best sounding 4 cylinder ever made- in my opinion. I def know it would not be as easy as a subaru or V8 swap. Not the biggest fan of V8s so the subaru motor would probably be the easiest choice for me. Anyways.. hopefully I get it running soon. I'm thinking it could be as soon as this weekend. I haven't actually attempted to start it since I got it, haha. |
Lo-Fi Version | Time is now: 26th April 2024 - 03:06 AM |
