New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
Chris914n6 |
Nov 10 2018, 01:07 AM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
More motivation... K20A2 Porsche 911
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1541833657.1.jpg) I did my Nissan VQ30DE swap back in 2000 before forums existed. Fairly easy to do. The most time consuming part was going page by page thru the FSM to find and wire the dozen separate ECU power connections and the gauge wiring. Then after it's running you have to go thru it all again to make it pretty... it's one of the laws of swapping (IMG:style_emoticons/default/av-943.gif) Don't listen to the old folks... 200hp IS the sweet spot. A T4 power build makes sense if you do it yourself, then the bill is under $2k. Otherwise a modern FI motor swap makes more sense. My old timer advice is to attend one of the World events next year and drive a few cars. Then you will have a strong basis to decide on your power level and swap difficulty. |
Dave_Darling |
Nov 11 2018, 01:35 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Chris914n6 |
Nov 11 2018, 09:58 PM
I did my Nissan VQ30DE swap back in 2000 before forums existed.... I have heard either this car, or another one with the same engine, running. The engine note is FECKING EERIE!!! Sent chills up my spine. Very cool swap, though not a car I would own. --DD Probably WCC'05 in Reno/Tahoe area. Had it WOT up the hill after the candy store stop and several people commented. The 911 stock banana muffler worked out really well in the sound department. |
Lo-Fi Version | Time is now: 26th April 2024 - 12:47 PM |
