How do you remove the crash bars on late doors? |
dan10101 |
Nov 9 2018, 09:33 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Yes, I have a cage and I will have door bars.
So I looked and looked, but can't find a write up on how to remove the factory crash bars on late doors? I have 1/2 of it out, but the door latch side is a puzzlement. So far I've cut them in half and was able to cut out the front hinge side. Can someone help? |
Literati914 |
Nov 9 2018, 11:15 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
..Yes, I have a cage and I will have door bars. I'm confused, but whats new!! I mean... you're cutting bars out of these doors to put into your existing doors? As-in "I WILL have door bars if it's the last thing I do!! (IMG:style_emoticons/default/av-943.gif) .."Or, these are your existing doors and you're cutting the stock bars out (to save weight) because your roll cage has door bars already? Sorry I'm no help. I would have cut the sections out of the each outside end and pulled it out as a whole unit, probably. EDIT: ok we must have been typing at the same time. I see now, you're saving weight. Good job! |
dan10101 |
Nov 9 2018, 11:47 PM
..Yes, I have a cage and I will have door bars. I'm confused, but whats new!! I mean... you're cutting bars out of these doors to put into your existing doors? As-in "I WILL have door bars if it's the last thing I do!! (IMG:style_emoticons/default/av-943.gif) .."Or, these are your existing doors and you're cutting the stock bars out (to save weight) because your roll cage has door bars already? Sorry I'm no help. I would have cut the sections out of the each outside end and pulled it out as a whole unit, probably. EDIT: ok we must have been typing at the same time. I see now, you're saving weight. Good job! Yes, it's replacing one door bar with another. Hopefully saving weight with all this work. (IMG:style_emoticons/default/smile.gif). I'm hoping a tube will weigh less than 14#s. Actually, I'm hoping to save 25# per door. We'll see. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:15 PM |
