How do you remove the crash bars on late doors? |
dan10101 |
Nov 9 2018, 09:33 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Yes, I have a cage and I will have door bars.
So I looked and looked, but can't find a write up on how to remove the factory crash bars on late doors? I have 1/2 of it out, but the door latch side is a puzzlement. So far I've cut them in half and was able to cut out the front hinge side. Can someone help? |
Mike Bellis |
Nov 10 2018, 11:29 AM
I don't think the weight savings is worth the safety trade off. Especially since with your HP & torque, you will never feel the difference.
dan10101 |
Nov 10 2018, 11:48 AM
I don't think the weight savings is worth the safety trade off. Especially since with your HP & torque, you will never feel the difference. Probably not, but I can't get out of my head how much a porker it is. Almost 2600# before I started with it. heck, my 944 was 2900. What does yours weigh? Joe Sharp, I can't get over your's being 1000# lighter.... I'm enjoying reading your thread.. Thanks. |
Mike Bellis |
Nov 10 2018, 12:09 PM
I don't think the weight savings is worth the safety trade off. Especially since with your HP & torque, you will never feel the difference. Probably not, but I can't get out of my head how much a porker it is. Almost 2600# before I started with it. heck, my 944 was 2900. What does yours weigh? Joe Sharp, I can't get over your's being 1000# lighter.... I'm enjoying reading your thread.. Thanks. I'm just under 2300 lbs. Not sure where you extra 300 came from. Although I could be a little heavier since I added caging up front and tied in my tow bar connections. Still your going to be close to 500ft lbs pushing that thing. You won't feel the added couple pounds. |
dan10101 |
Nov 10 2018, 01:36 PM
I don't think the weight savings is worth the safety trade off. Especially since with your HP & torque, you will never feel the difference. Probably not, but I can't get out of my head how much a porker it is. Almost 2600# before I started with it. heck, my 944 was 2900. What does yours weigh? Joe Sharp, I can't get over yours being 1000# lighter.... I'm enjoying reading your thread.. Thanks. I'm just under 2300 lbs. Not sure where you extra 300 came from. Although I could be a little heavier since I added caging up front and tied in my tow bar connections. Still your going to be close to 500ft lbs pushing that thing. You won't feel the added couple pounds. I'm not sure that everything fiberglass is saving any weight. It's nice solid fiberglass, thick stuff, not the flimsy stuff I've seen. That said, except for doors, A pillars and sail panels, everything exposed is fiberglass. Oh, and the engine lid is stock. But the cage is very well constructed. Full interior with 4 speaker stereo. Plus a few added pieces that probably are heavier than they need to be. I'm curious about how your added bars up front. That's one area I will likely be adding tubing. Back to cutting on the door. (IMG:style_emoticons/default/sawzall-smiley.gif) |
rgalla9146 |
Nov 10 2018, 02:13 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I don't think the weight savings is worth the safety trade off. Especially since with your HP & torque, you will never feel the difference. Probably not, but I can't get out of my head how much a porker it is. Almost 2600# before I started with it. heck, my 944 was 2900. What does yours weigh? Joe Sharp, I can't get over yours being 1000# lighter.... I'm enjoying reading your thread.. Thanks. I'm just under 2300 lbs. Not sure where you extra 300 came from. Although I could be a little heavier since I added caging up front and tied in my tow bar connections. Still your going to be close to 500ft lbs pushing that thing. You won't feel the added couple pounds. I'm not sure that everything fiberglass is saving any weight. It's nice solid fiberglass, thick stuff, not the flimsy stuff I've seen. That said, except for doors, A pillars and sail panels, everything exposed is fiberglass. Oh, and the engine lid is stock. But the cage is very well constructed. Full interior with 4 speaker stereo. Plus a few added pieces that probably are heavier than they need to be. I'm curious about how your added bars up front. That's one area I will likely be adding tubing. Back to cutting on the door. (IMG:style_emoticons/default/sawzall-smiley.gif) Full cage, empty doors...... full interior....four speaker stereo ? 2600 lbs. ! Very confusing. What is it ? |
Lo-Fi Version | Time is now: 16th May 2024 - 09:24 PM |
