Cleaning MPS and Decel Valve, Adivce needed |
doug_b_928 |
Nov 14 2018, 06:23 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Just wondering what is the best way to clean these and if there's anything I need to make sure NOT to do. For a cosmetic cleaning of the outside I was thinking just some brake cleaner. Debris is visible inside the small port on the decel valve (debris can be seen in the third pic below) and I'm not sure the best way to get it out. Failing any advice to the contrary, I thought I'd gently insert a paper clip and dig it out. (P.S. I did the vacuum, resistance, and continuity tests on the MPS and it looks good).
JeffBowlsby |
Nov 14 2018, 07:08 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Small wire brush and elbow grease. Rattle can them, they will look great.
Lo-Fi Version | Time is now: 18th May 2024 - 03:41 AM |
