Cooling and necessary parts, What parts are necessary? |
pistonboy |
Nov 14 2018, 10:50 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
My friend and I had the heads rebuilt on a motor I have purchased. All thermostat parts have been removed including bellows, wire, rod, and flaps. I live in a desert and am not worried about cold weather since there is none, but I am concerned about cooling in the hot summer. I wanted to leave these thermostat parts out of the engine. My friend has a friend who is supposedly very familiar with these engines who says we should have the bar and flaps in the engine, but tie them permanently open. I believe the flaps are at slightly different angles on the rod. Is there a problem with leaving them out? I do not see a problem. What is your advice about this? Thank you. |
stevend914 |
Nov 14 2018, 11:16 PM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
You'll need the flaps to direct air to the oil cooler, especially in the summer
Nov 14 2018, 11:29 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is there a problem with leaving them out? I do not see a problem. Do a search here, as stated above, without the flaps you will get zero airflow through the stock oil cooler. If you plan to only do 2 minutes runs every other hour, by all means, go for it ... (IMG:style_emoticons/default/shades.gif) |
Tbrown4x4 |
Nov 15 2018, 03:51 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
It's pretty tough to outsmart a German Engineer. If they didn't think they were necessary, they wouldn't be there.
bbrock |
Nov 15 2018, 08:33 AM
And do NOT tie the flaps "open." The default position of the flaps provides max cooling. Personally, I think it's better to run the thermostat even in warm climates. The system is designed to get the engine up to operating temperature as quickly as possible and then open the flaps to keep it there. That's better for the engine than letting it run cold longer. You can get away with installing the flaps but not the thermostat, but it isn't ideal in any climate.
dr914@autoatlanta.com |
Nov 15 2018, 09:08 AM
914 Guru Group: Members Posts: 7,819 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you HAVE to have the flaps and thermostat installed. The thermostat allows for fast warmups and keeps the engine from building up moisture, the oil cooler flap forces air over the oil cooler.
Mark Henry |
Nov 15 2018, 10:00 AM
It's pretty tough to outsmart a German Engineer. If they didn't think they were necessary, they wouldn't be there. Say the flaps and T-stat only cost the factory $1 each/set X 120,000 914's, 22 million bugs and I don't how many ghia, T2, T3, T4. Do you really think VW would spent the coin if it wasn't required? Do you think you're smarter than the factory engineers? |
Nov 15 2018, 01:04 PM
A lot of people seem to; we've seen a whole lot of people who "don't need the damned flaps". They generally are of two types:
- Race car builders who have massively modified cooling systems - People who later complain about always running hot Some even fall into both of those camps... Bottom line: You absolutely MUST have the flaps installed, unless you have completely reworked the whole cooling system. It is best if you have the thermostat hooked up and working correctly, but it is not completely mandatory if you are willing to live with extra wear and tear on the motor. --DD |
914_teener |
Nov 15 2018, 01:19 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Got a whole new assembly for you if you need it.
Make me an offer and good luck. And yes you need it. |
914_teener |
Chris914n6 |
Nov 15 2018, 03:06 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I don't recall at what temp the thermostat opened but it was lower than any temp I would choose to drive the 914.
Cooling flap default, assuming assembled properly with the springs, is wide open. Also directs air to the oil cooler so it needs to be installed. *there is nothing more over engineered than a German car, which makes for a fat paycheck (IMG:style_emoticons/default/piratenanner.gif) |
Mark Henry |
Nov 15 2018, 03:35 PM
I don't recall at what temp the thermostat opened but it was lower than any temp I would choose to drive the 914. Cooling flap default, assuming assembled properly with the springs, is wide open. Also directs air to the oil cooler so it needs to be installed. *there is nothing more over engineered than a German car, which makes for a fat paycheck (IMG:style_emoticons/default/piratenanner.gif) Must be really hot as hell there. (IMG:style_emoticons/default/blink.gif) German stat for type IV carb and FI engines, and 4 cylinder Porsche 912 and 914 engines, starts to open at 85-90C (185-194F) http://www.awesomepowdercoat.com/thermosta...ed_rebuilt.html |
iankarr |
Nov 15 2018, 04:07 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Should we have a "WHY YOU NEED THE COOLING FLAPS" sticky? Methinks maybe.
Lo-Fi Version | Time is now: 26th April 2024 - 11:19 AM |
