Cooling and necessary parts, What parts are necessary? |
pistonboy |
Nov 14 2018, 10:50 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
My friend and I had the heads rebuilt on a motor I have purchased. All thermostat parts have been removed including bellows, wire, rod, and flaps. I live in a desert and am not worried about cold weather since there is none, but I am concerned about cooling in the hot summer. I wanted to leave these thermostat parts out of the engine. My friend has a friend who is supposedly very familiar with these engines who says we should have the bar and flaps in the engine, but tie them permanently open. I believe the flaps are at slightly different angles on the rod. Is there a problem with leaving them out? I do not see a problem. What is your advice about this? Thank you. |
SirAndy |
Nov 14 2018, 11:29 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is there a problem with leaving them out? I do not see a problem. Do a search here, as stated above, without the flaps you will get zero airflow through the stock oil cooler. If you plan to only do 2 minutes runs every other hour, by all means, go for it ... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 27th May 2024 - 09:02 PM |
