Cooling and necessary parts, What parts are necessary? |
pistonboy |
Nov 14 2018, 10:50 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
My friend and I had the heads rebuilt on a motor I have purchased. All thermostat parts have been removed including bellows, wire, rod, and flaps. I live in a desert and am not worried about cold weather since there is none, but I am concerned about cooling in the hot summer. I wanted to leave these thermostat parts out of the engine. My friend has a friend who is supposedly very familiar with these engines who says we should have the bar and flaps in the engine, but tie them permanently open. I believe the flaps are at slightly different angles on the rod. Is there a problem with leaving them out? I do not see a problem. What is your advice about this? Thank you. |
dr914@autoatlanta.com |
Nov 15 2018, 09:08 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you HAVE to have the flaps and thermostat installed. The thermostat allows for fast warmups and keeps the engine from building up moisture, the oil cooler flap forces air over the oil cooler.
Lo-Fi Version | Time is now: 19th May 2024 - 02:52 AM |
