Cooling and necessary parts, What parts are necessary? |
pistonboy |
Nov 14 2018, 10:50 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
My friend and I had the heads rebuilt on a motor I have purchased. All thermostat parts have been removed including bellows, wire, rod, and flaps. I live in a desert and am not worried about cold weather since there is none, but I am concerned about cooling in the hot summer. I wanted to leave these thermostat parts out of the engine. My friend has a friend who is supposedly very familiar with these engines who says we should have the bar and flaps in the engine, but tie them permanently open. I believe the flaps are at slightly different angles on the rod. Is there a problem with leaving them out? I do not see a problem. What is your advice about this? Thank you. |
914_teener |
Nov 15 2018, 01:19 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Got a whole new assembly for you if you need it.
Make me an offer and good luck. And yes you need it. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:39 AM |
