Master Cylinder Rubber Grommet Seating Tool, Seems they pulled loose when the MC was installed |
ctc911ctc |
Nov 16 2018, 01:28 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
mepstein |
Nov 16 2018, 01:31 PM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Did you install the metal washer under the grommet. It’s ok to reuse the old ones if your new MC didn’t include them but they have to be installed. They go in first.
ctc911ctc |
Nov 16 2018, 02:10 PM
Did you install the metal washer under the grommet. It’s ok to reuse the old ones if your new MC didn’t include them but they have to be installed. They go in first. Hhhmmm, bought the MC from a reputable vendor. Took out the grommets to get the pipes in place.....did not see the washers - will check with the vendor. |
mepstein |
Nov 17 2018, 09:23 AM
Did you install the metal washer under the grommet. It’s ok to reuse the old ones if your new MC didn’t include them but they have to be installed. They go in first. Hhhmmm, bought the MC from a reputable vendor. Took out the grommets to get the pipes in place.....did not see the washers - will check with the vendor. Some MC's include them, some don't. Doesn't matter. You need them under the bushing or it will leak. |
Lo-Fi Version | Time is now: 20th May 2024 - 06:05 AM |
