Master Cylinder Rubber Grommet Seating Tool, Seems they pulled loose when the MC was installed |
ctc911ctc |
Nov 16 2018, 01:28 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Mikey914 |
Nov 17 2018, 01:21 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is the reason I developed the alternate version of the Master cylinder that does not use the rubber grommets. these are troublesome to install and yes a pain in the butt to do.
One disconnect we have had is the basic master cylinder did not get shipped with the washers, as we were working out the details of the manufacture with the idea that we would make only the one version. It was a n afterthought to make a less expensive stock option. We intended to source or produce the washers but this didn't happen. We are in the process of doing that now. Still the easy install kit solves this problem, but if you want a "stock" solution we will be starting to include shortly. |
Lo-Fi Version | Time is now: 20th May 2024 - 05:40 AM |
