Master Cylinder Rubber Grommet Seating Tool, Seems they pulled loose when the MC was installed |
ctc911ctc |
Nov 16 2018, 01:28 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
ctc911ctc |
Nov 19 2018, 08:55 AM
********UPDATE*********
Fixed all of the leaks, the grommets are in as far as I believe they will go. Re-bled the system. No bubbles, went around twice. Hooked up the emergency brakes, tight, tight, tight! Put the tires on and drove the car down the street and back. First time the car has moved on it's own power since '84. TWO OBSERVATIONS - any comments or direction are appreciated. 1. Rear brakes are too tight (dragging) so I need to adjust "venting clearance" ? Correct? 2. Brake pedal travels half-way on the first push, high and tight on the second. Need guidance here - what should I look at first? Thank you all 914W gurus. CTC911CTC My 17yr old son and I replaced the MC with a new one last week - since it was VERY cold here in New England we may have not taken the care the job deserved. Once installed I noticed that there was leaking from the reservoir hoses, the grommets seemed to have pulled loose. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:33 AM |
