lwells8433 |
Newbie ![]() Group: Members Posts: 4 Joined: 13-January 18 From: Los Alamitos Member No.: 21,796 Region Association: Southern California ![]() |
I am restoring a 1973 914 2.0l
One thing that I cannot get right or to work correctly are those rubber strips that go on the outside of the door windows that squeegees the water and keeps the water out. I bought multiple pieces from different websites and even from a local shop. When you roll window up it’s good but when you roll the window down it pulls the rubber piece down with it. I know that everything is installed correctly, my father in law use to own a restoration shop for Porsche and I had him check everything. We have not been able to figure out the best way to make this work. Do we cut the rubber to make it work or is there a rubber piece from another car we can use. I know this is a known issue but I need some help to get this figured out. Thanks |
RAX914 |
Member ![]() ![]() Group: Members Posts: 109 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None ![]() ![]() |
Get it from 914rubber. They will probably be a part of tomorrow's Black Friday sale:
https://900designs-container.zoeysite.com/l...craper-seal-set |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,288 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
I don't believe I have seen that problem before. I still have some old stock from many years ago. However, it would seem that the rubber is a bit too sticky so perhaps a bit of silicone solution could be applied to the rubber. I am not sure if Rain-x would help if applied to the glass.
Lo-Fi Version | Time is now: 1st July 2025 - 01:48 AM |
