Window Scraper Install Question, Scraper is binding against the window |
Highland |
Nov 27 2018, 11:51 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm putting my door back together and have everything in including the fuzzies on both sides. The window goes up and down smoothly until I install the scraper. Going up I can here the rubber scraping against the window and going down it can bind bad enough the friction from the window starts to fold the scraper over.
I removed the from trim guide to give the glass more freedom and tried supporting the glass manually and the rubber scraper still binds. Advice please.? |
76-914 |
Nov 27 2018, 02:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
!) Did you remove the alum bar that holds the rubber piece. If so did you re-install it using the same screws holes? If it was installed a bit low it will do as you are describing.
2) Can you see a small hump running lengthwise down the middle of the rubber strip. If so it isn't seated properly. 3) Does the window glass mate properly with the top and back side? 4) Does it free up if the interior door card is removed? 5) Is the rubber strip oriented correctly. It can installed backwards. (IMG:style_emoticons/default/beerchug.gif) |
dr914@autoatlanta.com |
Nov 27 2018, 02:14 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
wax your window
I'm putting my door back together and have everything in including the fuzzies on both sides. The window goes up and down smoothly until I install the scraper. Going up I can here the rubber scraping against the window and going down it can bind bad enough the friction from the window starts to fold the scraper over. I removed the from trim guide to give the glass more freedom and tried supporting the glass manually and the rubber scraper still binds. Advice please.? |
Lo-Fi Version | Time is now: 19th May 2024 - 06:46 PM |
