How do the sunvisors work? Yes - I am really asking that... |
mark04usa |
Dec 3 2018, 12:07 AM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
Well, differ all you want to, Lawrence...but you are incorrect as shown by the photos. (IMG:style_emoticons/default/smile.gif) I guess the post was not read and understood??? As the photo I took shows, I followed Tom's description, and you can see that my sun visor does swivel out because the outter bracket is made to do this. Even has a bump stop at 90 angle. Try it, and you will see that it does work...just not very well as it is setup in a 914.
GaroldShaffer |
Dec 3 2018, 12:16 AM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
They don't swivel. There is a pin on each end that is attached to a clip. So does yours have the clip at the center of the windshield by the mirror? If so, I would like to see how it is held in place as they are not designed swivel to the side.
mark04usa |
Dec 3 2018, 12:25 AM
They don't swivel. There is a pin on each end that is attached to a clip. So does yours have the clip at the center of the windshield by the mirror? If so, I would like to see how it is held in place as they are not designed swivel to the side. Gerald, please read Tom's post...and mine...and look at the photos. I tried using the visor just as Tom described (yes, mine are original 1970 visors and hardware)....and mine do indeed swivel. So, though I did not believe that Tom was correct, I did the next step and actually investigated. I would suggest you guys actually read what was stated and try for yourselves before you try to further argue with my photo (IMG:style_emoticons/default/biggrin.gif) |
TheCabinetmaker |
Dec 3 2018, 07:24 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
So, you have to leave the screw on the outside mount loose, then remove the visor from the center pin to swivel it? I do not believe Porsche engineers designed it this way. I bought my first 914 from the dealer brand new in 1973. All the screws on the visor mounts were tight. If they really meant it to swivel, they would have come up with something better than that. If you leave that screw loose the weight of the visor will eventually strip the hole where the sheet metal screw inserts. Just my opinion
Dec 3 2018, 08:02 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just because you can do it, doesn't mean you should do it.
Tdskip |
Dec 3 2018, 08:40 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Just because you can do it, doesn't mean you should do it. Where were you with that advise oh, say, 15 years ago? (IMG:style_emoticons/default/biggrin.gif) Back on topic - I am happy this seemingly simple question has spawned this level of discussion and information sharing. |
GaroldShaffer |
Dec 3 2018, 12:59 PM
They don't swivel. There is a pin on each end that is attached to a clip. So does yours have the clip at the center of the windshield by the mirror? If so, I would like to see how it is held in place as they are not designed swivel to the side. Gerald, please read Tom's post...and mine...and look at the photos. I tried using the visor just as Tom described (yes, mine are original 1970 visors and hardware)....and mine do indeed swivel. So, though I did not believe that Tom was correct, I did the next step and actually investigated. I would suggest you guys actually read what was stated and try for yourselves before you try to further argue with my photo (IMG:style_emoticons/default/biggrin.gif) I did read it. They don't swivel, not by design anyway. Show me how yours are mounted by the center pin. The only way you can do it is by what Curt said and that is not how they are designed to work. |
Dec 3 2018, 01:08 PM
Just because you can do it, doesn't mean you should do it. Where were you with that advise oh, say, 15 years ago? (IMG:style_emoticons/default/biggrin.gif) 35 years ago. My first 914. I was 17. Driving through the snow with a pretty girl in the passenger seat. Drove by a sledding hill. Used the targa top as a sled. It worked but I’m betting the Porsche designers wouldn’t have approved. |
TheCabinetmaker |
Dec 3 2018, 04:29 PM
Nor would your peers here today! Lol
scallyk9 |
Dec 3 2018, 05:53 PM
Member Group: Members Posts: 323 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
This post is fun. Porsche 914 Design Team in 1970, "Hey team, if the owner's screw is loose he can rotate the visor for side window use. Porsche Cayenne design team in 2009. "Hey team, let's overdesign this visor so much that it will require two pages to describe in the owner's manual. My '09 CTTS has a dual visor arrangement on each side with the front one not only hinged but pivoting while the one behind it is only vertically hinged. My old Cayenne S TE even had a third visor in the center to flip down to block the area above the rear view mirror. Yup, if they had designed the 914's visors to pivot horizontally it would be obvious and not based on a loosened fitting.
Dec 3 2018, 05:57 PM
This post is fun. Porsche 914 Design Team in 1970, "Hey team, if the owner's screw is loose he can rotate the visor for side window use. Porsche Cayenne design team in 2009. "Hey team, let's overdesign this visor so much that it will two pages to describe in the owner's manual. My '09 CTTS has a dual visor arrangement on each side with the front one not only hinged but pivoting while the one behind it is only vertically hinged. My old Cayenne S TE even had a third visor in the center to flip down to block the area above the rear view mirror. Yup, if they had designed the 914's visors to pivot horizontally it would be obvious and not based on a loosened fitting. (IMG:style_emoticons/default/agree.gif) German, not British. |
bbrock |
Dec 3 2018, 06:08 PM
Just because you can do it, doesn't mean you should do it. Where were you with that advise oh, say, 15 years ago? (IMG:style_emoticons/default/biggrin.gif) 35 years ago. My first 914. I was 17. Driving through the snow with a pretty girl in the passenger seat. Drove by a sledding hill. Used the targa top as a sled. It worked but I’m betting the Porsche designers wouldn’t have approved. (IMG:style_emoticons/default/bs.gif) If they'd have thought of that, it would be in a brochure somewhere. They didn't design the hood as a tanning bed either. Yet, there are those two bikini chicks. (IMG:style_emoticons/default/biggrin.gif) |
Dec 3 2018, 06:49 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I am curious about what happens to the center pivot when people swivel their visors to the side.
I did have one that did that, but the center pivot had broken. The plastic around the metal pin on the driver's side had failed, so the pin would not stay in the plastic part. Then, if the side screw were loose, you could actually pivot the visor to the side. It would do that on its own, in fact. Because the center mount was broken, you see. That being said, I do have visors that swivel in my car. Someone along the way designed (or adapted from another car) a center pivot that has small concavities that the inboard pins fit into. The outer pivots were re-designed with a cylindrical piece that does pivot on an offset screw near the mounting screw. They don't work very well, though. The concavities don't hold the inboard pins very well, so they tend to flop around. Also, the mounting screw loosens up when you swivel the shades more than a couple of times, so the whole thing starts moving in an odd way. ... But the stock setup doesn't pivot unless something is broken ... --DD |
raynekat |
Dec 3 2018, 06:54 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I agree.
Stock setup when correctly installed and the screws are tight.....sunvisors do not swivel. And were never designed to do so. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:24 PM |
