amfab |
Member ![]() ![]() Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None ![]() ![]() |
I always assumed the big holes—the 3 or 4 inch diameter ones like in the floor pan and the rear trunk floor that have the twist-in caps—were for spot welder access during manufacturing.
I see there are some other smaller detents—maybe 1-3/4in diameter with half moon cut outs creating a sort of flap near the pedal cluster for example. Were these for the same purpose? Maybe they had an odd spot weld to get to, so they bent them open, did the weld, then bent them back and seam sealed them closed? If this is the case, is there any reason—other than authenticity—to not weld them closed while I am cleaning up the body before blasting and priming? Thanks In advance -Andrew |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,612 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
I always assumed the big holes—the 3 or 4 inch diameter ones like in the floor pan and the rear trunk floor that have the twist-in caps—were for spot welder access during manufacturing. I see there are some other smaller detents—maybe 1-3/4in diameter with half moon cut outs creating a sort of flap near the pedal cluster for example. Were these for the same purpose? Maybe they had an odd spot weld to get to, so they bent them open, did the weld, then bent them back and seam sealed them closed? If this is the case, is there any reason—other than authenticity—to not weld them closed while I am cleaning up the body before blasting and priming? Thanks In advance -Andrew I would think you could weld them up no issue.. |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
I thought maybe the c-shaped slots were for drainage when the chassis was dipped but really have no clue. They had little metal discs glued over them with seam sealer. When I replaced my floor, I went to great pains to re-cut the openings for the twist on spot weld plugs, but I didn't re-cut those slots. I did replace the metal discs in the divots only because I'm a freak. I don't think it matters if you weld or seal as long as they are closed up.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,835 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I always thought the holes in the front nose panel and pan were for when the chassis were dipped on assembly line
second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
Dipped for what?
gg |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,021 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
If it happened the heat tube mufflers would be primed inside and out.
bbrock |
I thought they dipped them for that PVC (IMG:style_emoticons/default/stromberg.gif) that is such a PITA when stripping the car.
amfab |
The only dipping that makes sense to me is a a nice mild acid or salt water dip based on what I am seeing taking this car apart—probably did it on a dolly that tilted the car backwards about 10 degrees.
-Andrew |
jtprettyman |
Rust Bucket Owner ![]() ![]() Group: Members Posts: 109 Joined: 5-May 15 From: Murfreesboro Tennessee Member No.: 18,707 Region Association: South East States ![]() ![]() |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,412 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
For the 911's the factory started galvanizing bodies starting in 1977 I think, so after 914 production ended. My 1980 911 Targa showed no rust.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
The big holes with the twist in plugs were used to secure the panels to the jigs during the assembly of the unibody. I have seen a film on the 356 where they show the panels attached to the jigs.
Lo-Fi Version | Time is now: 18th July 2025 - 07:49 PM |
