WTB 1973 1.7 FI, 1.7 Fuel Injection Components |
joeswaim |
Dec 3 2018, 02:10 PM
Newbie Group: Members Posts: 5 Joined: 4-December 15 From: Roswell Ga Member No.: 19,433 Region Association: South East States |
I am looking for Fuel Injection parts for a 1.7L 1973.
I need an ECU bracket preferably serial number 0 280 000 037. or 013 or 038. Also, I need the MPS serial number 0 280 100 049. FI Electrical harness Throttle body Fuel pressure regulator Auxiliary air valve regulator Air temp sensor Cold start valve Thermo time switch Deceleration valve Fuel Pump Thanks Joe |
JoeD |
Dec 3 2018, 04:15 PM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
I am looking for Fuel Injection parts for a 1.7L 1973. I need an ECU bracket preferably serial number 0 280 000 037. or 013 or 038. Also, I need the MPS serial number 0 280 100 049. FI Electrical harness Throttle body Fuel pressure regulator Auxiliary air valve regulator Air temp sensor Cold start valve Thermo time switch Deceleration valve Fuel Pump Thanks Joe Joe, I have the complete FI setup from a 1.7 that was pulled when I went Raby 2270 and carbs. Ran when pulled. Includes a rebuilt MPS that I bought from Brad Mayeur (I think) and a rebuilt Bowlsby wiring harness with only a couple hundred miles on it. I do not think I still have fuel pump but maybe. Otherwise most everything else is there -,as I said, the car was running well before I sent it to Jake. Here’s the crazy part- I’m in Atlanta so just down the road if you’re in Roswell. Parts have in a storage place off Peachtree Inustrial in Dunwoody for a couple years. I’d have to get out there and grab them but yours if you want. PM me... Joe |
Lo-Fi Version | Time is now: 7th May 2024 - 07:30 AM |
