QUOTE(joeswaim @ Dec 3 2018, 03:10 PM)
I am looking for Fuel Injection parts for a 1.7L 1973.
I need an ECU bracket preferably serial number 0 280 000 037. or 013 or 038.
Also, I need the MPS serial number 0 280 100 049.
FI Electrical harness
Throttle body
Fuel pressure regulator
Auxiliary air valve regulator
Air temp sensor
Cold start valve
Thermo time switch
Deceleration valve
Fuel Pump
Thanks
Joe
Joe,
I have the complete FI setup from a 1.7 that was pulled when I went Raby 2270 and carbs. Ran when pulled. Includes a rebuilt MPS that I bought from Brad Mayeur (I think) and a rebuilt Bowlsby wiring harness with only a couple hundred miles on it. I do not think I still have fuel pump but maybe. Otherwise most everything else is there -,as I said, the car was running well before I sent it to Jake.
Here’s the crazy part- I’m in Atlanta so just down the road if you’re in Roswell. Parts have in a storage place off Peachtree Inustrial in Dunwoody for a couple years. I’d have to get out there and grab them but yours if you want.
PM me...
Joe
