oil level, refer to photo please |
Jetsetsurfshop |
Dec 10 2018, 08:40 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
How in the hell do you check your oil level with a set-up like this? Or even with the factory -6 set-up?
Attached thumbnail(s) |
yeahmag |
Dec 10 2018, 03:44 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Way less critical than a wet sump motor. I run mine about 2/3-3/4 full with the engine warm and idling.
stownsen914 |
Dec 12 2018, 11:29 AM
Yup, what he said. Just open the cap and look down inside.
naro914 |
Dec 12 2018, 11:45 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
We created a small dipstick that I would stick down in to measure.
Factory style (PMS) oil tanks have a dipstick that fits inside the cap just like a normal oil tank. Dry sump systems need to be measured hot, while running, and on a level surface. you CAN overfill it....and its not pretty... |
Jetsetsurfshop |
Dec 13 2018, 10:48 AM
Checking the tank level is what i figured.
Thanks for helping this old guy (IMG:style_emoticons/default/beer.gif) |
GregAmy |
Dec 13 2018, 10:58 AM
Advanced Member Group: Members Posts: 2,284 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
If it help any, I'm using this tank in my racer:
https://www.summitracing.com/parts/ctr-23-110r It has a "shelf" as a baffle toward the top and I got tired of opening the tank and not really being able to see down inside, just guessing. I had Chris weld in a bung so that I could use a stock Type 4 dipstick on the top without having to remove the cover. An alternative, preferred idea would be to fabricate a clear sight tube on the side of the tank so you could see it in real time. |
buz914 |
Dec 13 2018, 09:04 PM
Newbie Group: Members Posts: 26 Joined: 30-April 16 From: Florida Member No.: 19,952 Region Association: South East States |
I use a wood dowel and mark it with a sharpie where you like it.
Also I like to run a heat strip on the tank to plug it in when the temps get a little low at the track, takes a lot less time to warm all that oil up and less risk of spiking the oil pressure on cold start/warm up. |
yeahmag |
Dec 13 2018, 09:38 PM
Jetsetsurfshop |
Dec 14 2018, 09:45 AM
I use a wood dowel and mark it with a sharpie where you like it. Also I like to run a heat strip on the tank to plug it in when the temps get a little low at the track, takes a lot less time to warm all that oil up and less risk of spiking the oil pressure on cold start/warm up. I've heard of heating the oil pre start before. Do you do this on every startup? Just morning?? Is there an outside temp where you think its not necessary? I live in south Florida, wonder if i need it? |
yeahmag |
Dec 14 2018, 11:07 AM
On mine (the orange panel on the bottom) I tend to only do it on cold starts below about 60F. It really helps get the oil pressure down to a passable level before I hit the freeway on a cool CA morning. I'd say not necessary, but nice to have.
Now I need to figure out how to run it at an event! The fall and winter events here cool the oil down below 100F between sessions and the temp will not move just idling in the paddock. Going from 0 - 7000+ RPM for 55 seconds may not be the best thing for cool oil... I've considered bringing an inverter and running it off my battery or a support cars battery. |
naro914 |
Dec 14 2018, 11:29 AM
I've heard of heating the oil pre start before. Do you do this on every startup? Just morning?? Is there an outside temp where you think its not necessary? I live in south Florida, wonder if i need it? We use our heater every time morning, though we have power in our trailer so it’s easier. Plug it in when we get to the track, unplug before our first run and good for the day. Engine needs to be up to temp before we stress it under load, so this is the quickest way to get a head start on it...saves fuel from not having to sit as long idling to warm up. You can barely see it around the middle/bottom of the tank. |
Lo-Fi Version | Time is now: 4th May 2024 - 05:40 PM |
