How do you tel what rear springs you have? |
Tdskip |
Dec 13 2018, 10:06 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Time to educate myself on the rear suspension, it seems that the rear springs and shocks have quite a bit of options. Also seems that rear springs are the way to lower the car (seems obvious when I type that) and will have a big impact on ride stiffness.
Is there a way to tell what spring you have, maybe starting with ride height? Are the springs unique colors (common on Alfa’s) to make identification easier? Thanks! |
Dave_Darling |
Dec 13 2018, 11:46 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Stock springs would have paint dots on them denoting spring rate. They were all in the ~50 lb/in range.
Aftermarket springs may have letters and numbers painted or printed on them. That's about it, though. The best way to tell what you have is to pull them off the car and measure them. Compress the spring by some amount of inches, measure how much weight it took to do that. Or put so much weight on the spring and measure how far it compresses. --DD |
Tdskip |
Dec 14 2018, 07:04 AM
Stock springs would have paint dots on them denoting spring rate. They were all in the ~50 lb/in range. Aftermarket springs may have letters and numbers painted or printed on them. That's about it, though. The best way to tell what you have is to pull them off the car and measure them. Compress the spring by some amount of inches, measure how much weight it took to do that. Or put so much weight on the spring and measure how far it compresses. --DD Thanks, as always, Dave, I am asking because on this particular ‘74 the rear suspension seems much harsher than the other cars. Not sure if it is shocks or springs but needed the spring tutorial to start figuring it out. |
mepstein |
Dec 14 2018, 07:34 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Stock springs would have paint dots on them denoting spring rate. They were all in the ~50 lb/in range. Aftermarket springs may have letters and numbers painted or printed on them. That's about it, though. The best way to tell what you have is to pull them off the car and measure them. Compress the spring by some amount of inches, measure how much weight it took to do that. Or put so much weight on the spring and measure how far it compresses. --DD Thanks, as always, Dave, I am asking because on this particular ‘74 the rear suspension seems much harsher than the other cars. Not sure if it is shocks or springs but needed the spring tutorial to start figuring it out. I've never purchased a 914 (20 of them) where the rear shocks and springs were any good. It could be yours are just worn out no matter what the spring rate is. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:10 PM |
