914-6 Gt front track width, Front suspension |
dazpugh |
Dec 14 2018, 05:37 AM
Newbie Group: Members Posts: 11 Joined: 5-February 12 From: Kelowna BC Member No.: 14,093 Region Association: Canada |
Hi all,
Does anyone know the measurement from hub to hub on a Gt? I have a GT clone with steel arches and spacers on the front but want to know the original width of the track. Cheers |
ConeDodger |
Dec 14 2018, 07:07 AM
Apex killer! Group: Members Posts: 23,569 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The same as a 914-6
TravisNeff |
Dec 14 2018, 07:38 AM
(IMG:style_emoticons/default/agree.gif) I think it is the same track width as stock
Attached thumbnail(s) |
dazpugh |
Dec 14 2018, 03:44 PM
so they both used spacers bolted to the hub? |
mb911 |
Dec 14 2018, 03:48 PM
914 Guru Group: Members Posts: 6,815 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I wondered the same thing as I running 7 and 8s and from the looks of it 8s and 9s would be an easy fit..
TravisNeff |
Dec 14 2018, 03:50 PM
I think they came with 15x6 wheels and no spacers. It was up to the customers to change it up I believe.
dazpugh |
Dec 15 2018, 03:03 AM
i ask the question as i see cars with GT arches that are really low at the front whereas if i drop mine at the front the tyre catches the arch on full lock if i hit a bump.What size spacers are you guys using?
mepstein |
Dec 15 2018, 06:19 AM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
i ask the question as i see cars with GT arches that are really low at the front whereas if i drop mine at the front the tyre catches the arch on full lock if i hit a bump.What size spacers are you guys using? Tires have different profiles. Elephant has some stops to keep it from hitting at full lock but that's just the way some cars are. Spacers might help, a lot of guys run 944 turbo (24mm) spacers on the front. |
JFJ914 |
Dec 15 2018, 10:45 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
so they both used spacers bolted to the hub? They had 21mm spacers. |
Steve |
Dec 15 2018, 10:54 AM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
sixnotfour |
Dec 15 2018, 01:14 PM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
depends on tire size and how flairs where installed,,if this is your 914 ,
looks like you need to remove the spacer.. to go lower, and turn Attached image(s) |
sixnotfour |
Dec 15 2018, 01:19 PM
my 914 with 15x8 /9s 225/50 frnt 245/50 rears ,, good ole tires
Attached image(s) |
sixnotfour |
Dec 15 2018, 01:48 PM
I have early front hubs rotors, yours are prob. Carrera wich is a bit wider hub,, increasing track width
SirAndy |
Dec 15 2018, 02:04 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The same as a 914-6 (IMG:style_emoticons/default/agree.gif) The factory GTs usually ran 7"/9" wheels with spacers ... (IMG:style_emoticons/default/idea.gif) Attached thumbnail(s) |
sixnotfour |
Dec 15 2018, 09:27 PM
true ,, but ..not a factory GT..
SirAndy |
Dec 15 2018, 09:47 PM
true ,, but ..not a factory GT.. I have no idea what ,, or ..who your comment is aimed at.. (IMG:style_emoticons/default/unsure.gif) |
sixnotfour |
Dec 15 2018, 10:12 PM
the OG poster,,his post is misleading apples and oranges
ClayPerrine |
Dec 15 2018, 10:15 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you use 944 turbo wheels (951 part number), you don't need any spacers. The offset is correct for the 914-6.
sixnotfour |
Dec 15 2018, 10:57 PM
951,,911 x7 same offset,unless your referencing 8's
the silver pic is his 914-6 GT Clone |
dazpugh |
Dec 16 2018, 01:48 PM
That is my car.
I will try removing the spacers but will that give me a problem with hitting the inner arch on full lock. Thanks for all the input |
Lo-Fi Version | Time is now: 29th April 2024 - 03:21 AM |
