Fuel Pump Location? |
torakki |
Dec 14 2018, 09:03 PM
Newbie Group: Members Posts: 43 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
When I got this car and after trailering it home, the fuel pump was dangling under the car, held on by the fuel lines. The whole car was kind of a bucket but now it's getting restored and I'm not sure how the fuel pump is mounted. It's a '74 2.0 liter. The photos I see, show a pump on the firewall just to the right of the main wiring harness. But, I have no stud or mounting points there. Does it go on the bracket (photo)? Photos of correct location? Thanks for any input.
adolimpio |
Dec 14 2018, 09:10 PM
Art Group: Members Posts: 180 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
Chi-town |
Dec 14 2018, 09:54 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
If you're not going for the 100% correct restoration get a set of stainless steel fuel lines and mount the pump up front like they did in 75'
SirAndy |
Dec 14 2018, 10:01 PM
Resident German Group: Admin Posts: 41,612 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The original mounting holes are blocked by that hacked engine shelf repair. The bracket you pictured is for the fuel filter, not the pump.
But since this isn't a stock pump, it may not fit in the stock location. When i switched to a rotatry pump similar to yours on my carbed 2056, i mounted it on the firewall (with an inline filter *before* the pump), inbetween where the fuel lines exits the firewall and the heater duct opening. (IMG:style_emoticons/default/popcorn[1].gif) |
Spoke |
Dec 15 2018, 12:03 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You may want to pull those 40+ year old plastic tubes and replace with stainless from Tangerine Racing.
JawjaPorsche |
Dec 15 2018, 05:04 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I moved my fuel pump to the firewall. I removed the interior back pad. Then drilled two holes for the mounting bracket. I used large fender washers for the bolts which I inserted from the interior. Picture below will show location and configuration. Good luck and welcome newie!
Yes, replace those plastic lines especially since you have your car torn down, much easier! Attached image(s) |
Mark Henry |
Dec 15 2018, 06:35 AM
The pump you have is a very good, made in USA Walbro, http://walbrofuelpumps.com/walbro-gsl391-fuel-pump.html, but it is an inline FI pump so it would never fit the stock location. Stock pump for a '74 has the ports on the same end.
I'd never install a pump without rubber isolators or hose using worm gear hose clamps. |
torakki |
Dec 15 2018, 12:45 PM
OK, looks like my car has had some alterations in the past. I like the location of JawaPorsche's which may be the easiest way to solve this, since I will have to fab something. I'll use rubber insulators which I use from a $1.00 rubber floor mat from Dollar Tree. I cut strips off of it and works great. Not to concerned with originality but the car will probably be 95% original. Just personal touches that will make it more fun for me. Not sure I want to replace the plastic lines since I already installed the fuel tank, without scratching any of the new paint. Don't think I can do that twice.
Thanks for all the great info and photos. Really helps me out. |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:19 AM |
