Fuel Pump Location? |
torakki |
Dec 14 2018, 09:03 PM
Newbie Group: Members Posts: 43 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
When I got this car and after trailering it home, the fuel pump was dangling under the car, held on by the fuel lines. The whole car was kind of a bucket but now it's getting restored and I'm not sure how the fuel pump is mounted. It's a '74 2.0 liter. The photos I see, show a pump on the firewall just to the right of the main wiring harness. But, I have no stud or mounting points there. Does it go on the bracket (photo)? Photos of correct location? Thanks for any input.
JawjaPorsche |
Dec 15 2018, 05:04 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I moved my fuel pump to the firewall. I removed the interior back pad. Then drilled two holes for the mounting bracket. I used large fender washers for the bolts which I inserted from the interior. Picture below will show location and configuration. Good luck and welcome newie!
Yes, replace those plastic lines especially since you have your car torn down, much easier! Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:46 PM |
