E- Brake spring behind seat, How is it anchored ? |
jim_hoyland |
Dec 16 2018, 04:43 PM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The eBrake lever hasn’t been operating smoothly when releasing. At the firewall where the cables attach to the mechanism there is a short spring. It was not attached at the rear end; where does the spring attach ?
Attached image(s) |
rgalla9146 |
Dec 16 2018, 06:30 PM
Advanced Member Group: Members Posts: 4,555 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
There should be a metal tab with a hole in it attached to the bulkhead between
the cables. I recall it as horizontal but your spring which is correct says vertical. Anyone ? |
jim_hoyland |
Dec 16 2018, 06:58 PM
There should be a metal tab with a hole in it attached to the bulkhead between the cables. I recall it as horizontal but your spring which is correct says vertical. Anyone ? Got it. The upholstery shop was working in that area. They disconnected the spring and put a screw into that hole. The decree was holding the cover plate at the fire wall end. One other question, should there be a bolt securing the eBrake lever to the chassis. Right now it looks like it's riding on a busing and feels kinda wobbly. Didn't pull the seat yet, but can tomorrow... |
Lo-Fi Version | Time is now: 19th May 2024 - 01:58 PM |
