What is this switch? |
Bulldozer27 |
Dec 17 2018, 11:34 PM
Newbie Group: Members Posts: 48 Joined: 14-November 18 From: Sandy Eggo, CA Member No.: 22,653 Region Association: Southern California |
Apologies if covered many times before, but I did a search using multiple terms and got zip.
My question pertains to the knob 2nd from the left, just next to the headlight switch. What accessory is it for? I'm new to 914s and my car came with no manuals, accessories, or documentation, so please excuse my ignorance. In my case, it doesn't appear to control anything, but when the headlights are turned on, the center lights up orange. (IMG:http://www.914world.com/bbs2/uploads_offsite/i94.photobucket.com-22653-1545111281.1.jpg) |
RickS |
Dec 17 2018, 11:47 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Fog light switch. Should have a rubber surround with green face with a lamp face.
Larmo63 |
Dec 17 2018, 11:58 PM
That is an early 911 switch.
I think it was a replacement for the stock 914 foglight switch. |
JawjaPorsche |
Dec 18 2018, 05:43 AM
The switch probably works but your fog light bulbs probably need to be replaced. They only work when your headlights are on.
rgalla9146 |
Dec 18 2018, 07:01 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
That switch/knob is desirable in the early 911 world but the yellow 'jewel' that is illuminated when on is missing.
DickSteinkamp |
Dec 18 2018, 09:06 AM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
Should look like this...
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-20876-1545145612.1.jpg) To test your fog lights, make sure your key is "on" and your headlights are on and up and on low beam. |
Tom_T |
Dec 18 2018, 11:53 AM
Should look like this... (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-20876-1545145612.1.jpg) To test your fog lights, make sure your key is "on" and your headlights are on and up and on low beam. "Dozer" doesn't have his MY listed nor a in the VIN - so I'll just offer this clarification that the green bezel foglight switch was for 70-73 MY 914s, & the Amber bezel one was for 74-76 MYs. The Amber type looks similar, but their OEM Hella changed the color for whatever reason. Pick the color per your MY Dozer, & they're all around FS on here & 914club.com, evilbay, TheSamba.com, Pelican, CL, etc., as well as from Bruce Stone/bdstone & Curt/cabinetmaker & other members here - in both flavors - in quality ranging from NOS to driver or less, & priced accordingly. BTW - as an former Sandy Eggan 1963-71 - I love your location name play! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Jonathan Livesay |
Dec 18 2018, 12:06 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
You could probably get several of the correct 914 foglight switches for that thing.
https://www.ebay.com/itm/Original-Fog-Light...m4383.l4275.c10 |
dr914@autoatlanta.com |
Dec 18 2018, 12:30 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Bulldozer27 |
Dec 18 2018, 06:02 PM
Thanks for the help. I should have mentioned that it is a '71, but I don't know if this car was originally an Appearance Group car, so I don't know if the fog lights were original. What switch would have bee in this position assuming fog lights were not original?
1970 Neun vierzehn |
Dec 18 2018, 06:18 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
OEM fog light switch for my 1970/4, build date January 1970. Note, NO rubber surround. Fog lights are wired so they operate without the headlights being turned on or raised.
Paul Attached image(s) |
Bulldozer27 |
Dec 18 2018, 06:52 PM
OEM fog light switch for my 1970/4, build date January 1970. Note, NO rubber surround. Fog lights are wired so they operate without the headlights being turned on or raised. Paul Mine is a '71 with a build date of September 1970. How does your switch operate? Mine doesn't pull out or spin or anything. It just lights up when headlights are on. |
Dec 18 2018, 07:35 PM
The fog light switch is pulled out to operate the fog lights.
It is strange that your switch does not pull out. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:43 PM |
