big brakes, brakes |
firstknight13 |
Jun 19 2005, 10:05 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
ok i got a lot of $$ invested in the 4 bolt wheels and front bmw calipers and complete rear rebuild; so how do i get bigger brakes and keep the 4 lug set up ??? i'm totally into the new wrx conversion with the new hp i need bigger stopping power or so i was told....??? thanks. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
mihai914 |
Jun 19 2005, 10:39 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Billet hubs at your favorite club store (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
john rogers |
Jun 19 2005, 11:46 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I have the billet hubs and M calipers in front and BMW in the rear and at the circuit race in Tecate MX I could out brake both the all wheel drive Mitsu and Subaru but I also have Good year slicks and they had something else? I for get what but they were 225 size so I had a little tire foot print on them. I'd say try the new hubs as they seem to work great. I'll do a super speedway test this coming week where we go from 135 MPH to 35 MPH at turn 3 and a 110 MPH to 35 MPH stop each lap. With the BMW on both ends I could out brake most of the 2L 911s and 356s.
db9146 |
Jun 20 2005, 07:57 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Does anyone here offer caliper adapters for mounting larger Porsche calipers on struts with 3.5" spacing?
Thanks |
Joe Ricard |
Jun 20 2005, 09:22 PM
You know I have been on ths board for a darn long time. I used to praise the BMW upgrade on y 1st 914. Now that I have a stock set up that works great I dn't know what I was thinking. I do however have Really good pads both front and rear. I think Porterfield R4S. Definately not stock pads. 17mm M/C also.
I'll tell ya I can stop on the preverbial dime. Don't need no bigger brakes on the Autocross course either. So if you got to have bigger brakes you better get BIGGER tires that stick like glue because you will flat spot them easily. Better shocks to control the suspension under braking too. |
Eric_Shea |
Jun 20 2005, 09:31 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Read the article in the last issue of Pano. -or- What Joe said.
db9146 |
Jun 21 2005, 07:47 AM
With flares, a large six, coil over suspension at all four corners, 7s & 9s x 16, I think that bigger brakes are a part of the equasion. Are you suggesting that they aren't needed? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
I don't think so...... |
mihai914 |
Jun 21 2005, 08:04 AM
Can we guess all of this? I don't think so (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Mueller |
Jun 21 2005, 10:44 AM
he wasn't asking for advice, he just wants to know where to buy the stuff....the "details" don't matter (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) you can try Don Welch @ GPR, 800.321.5432 Ex 504 Don@GPRparts.com He was making a kit for using Boxster S(?) calipers for the 3.5" spacing struts.Not sure if he sells the adapters seperately or not.....I'd also look for ads in Panorama or Excellance. |
JmuRiz |
Jun 21 2005, 01:15 PM
914 Guru Group: Members Posts: 5,424 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I got my setup from Rich Johnson (a914guy) and am running Boxster brakes on the front with the 3.5" struts and a mounting bracket. You can buy all from him or separate. Stops as hard as your foot can stomp (since there's no assist or ABS, naturally), haha. |
Joe Ricard |
Jun 21 2005, 02:19 PM
Why only 7" fronts????
this is where all your braking happens. Seems like you are handicapping the big brakes with minimal contact patch. Get some REAL good tires OK.... My 8 x 15 rims nearly fit under stock front fenders. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) I'm putting 8.1 inches of rubber to the ground in front. If ya got to have big brakes you need BIG rubber. |
db9146 |
Jun 21 2005, 03:47 PM
You are correct 8s would be better...I am actively looking for a pair now. Know where I can find any of those? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Thanks for the input on where to buy. There are several companies advertising them in Excellence and Panos just thought I'd send the business towards another teener if possible. I've seen Rich's set up but I don't believe they will work with the set up I plan on using. |
jim912928 |
Jun 21 2005, 03:52 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
There was a thread in here where somebody was showing adapters they were making for boxster brakes for front and rear...here is the thread:
http://www.914world.com/bbs2/index.php?act=...=boxster+brakes wonder if he still makes them? |
firstknight13 |
Jun 21 2005, 07:32 PM
yes i'm gettin falken aziens 615 rt 205/50/15 so ditch the bmw calipers and go with ??? with the billet hubs and m''s??? i'm slow on some things also (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Mueller |
Jun 21 2005, 07:43 PM
the advantage of the billet hubs is the vented rotors, you'll get less brake fade due to the better cooling of the vented rotors and the nice aluminum heat sink of the new hub...................some people plan on using Volvo calipers (4 piston), but I do not know if they are running them yet....... |
bernbomb914 |
Jun 21 2005, 08:02 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
hub , vented disc, volvo 4 pot caliper
Bernie Attached image(s) |
bernbomb914 |
Jun 21 2005, 08:03 PM
zz
bernbomb914 |
xx
Joe Ricard |
Jun 21 2005, 08:54 PM
NOW THAT IS SOME SERIOUS PORN !
If you can't stop with that you might want to sell me your car. I'll put it to good use. |
cametal |
Jun 21 2005, 09:43 PM
autox'n Group: Members Posts: 76 Joined: 28-July 03 From: Oklahoma City, OK. Member No.: 960 |
What strut? What size master cyl? More info PLEASE! |
Lo-Fi Version | Time is now: 1st May 2024 - 09:51 PM |
