Valve adjustment, Doesn’t feel right? |
John90290 |
Dec 27 2018, 03:37 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
Got the part number off the exhaust valve. 021109612A
After an exhaustive (get it?) search on the inter web I can only find that it was used on type 4’s from 69-74. No mention of their sodium make up. All this to make sure I get them adjusted properly. |
Dec 27 2018, 11:04 PM
The sodium-filled 1.8 exhaust valves were not standard. I think they may have been an option, but they weren't standard issue. Just the 2.0 exhaust valves were sodium-filled as a matter of course.
Current thought is that the sodium isn't needed with modern materials. --DD |
John90290 |
Dec 29 2018, 09:36 PM
Painting the tins and found the sticker that called for .15mm
John90290 |
Dec 29 2018, 09:37 PM
Attached thumbnail(s) |
stugray |
Jan 6 2019, 09:07 PM
I use the TDC mark on the flywheel to set my valves.
There is the original at 0 deg TDC, and I put a second mark (with paint) at 180 deg. That way I can see the mark(s) from under the car and just turn one wheel to spin the engine. |
Shredhead |
Jan 7 2019, 04:49 PM
Member Group: Members Posts: 110 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States |
This animated gif helped me understand the Krusty method. There's a way (I can explain if need be) to look at the gif "frame by frame" to see what valves are closed when.
72hardtop |
Jan 22 2019, 03:22 AM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
No reason to use sodium valves today. None.
There are only 2 Type 4 head builders that I would allow.... Hoffman Automotive https://newsite.hamheads.com/ or Headflow Masters http://headflowmasters.com/ |
barefoot |
Jan 22 2019, 08:10 AM
Senior Member Group: Members Posts: 1,276 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:23 AM |
