Flywheel Fun, Some questions about compatibility |
TonyAKAVW |
Jun 20 2005, 12:12 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I am doing a Subaru conversion and got a very good deal on a KEP adapter plate and flywheel. Trouble is that the flywheel appears to be a 200 mm flywheel. It seems that I have a few options. I'm looking for some input on what to do...
My options (that I can think of): a) Use a 200 mm (VW) clutch and pressure plate (I don't even know if this is possible with a 901 transmission. Anyone know if this could work?) I would have to get a stiffer clutch to compensate for the smaller surface area I believe. b.) Have the flywheel machined to give me 215 mm of useable diameter. Also don't know if this is possible. c) Just get a new flywheel made for the 215mm clutch. d) Have the center of this new flywheel removed and get my stock 914 flywheel modified (not sure who would do this) e) ???????? -Tony |
Lo-Fi Version | Time is now: 17th May 2024 - 02:58 AM |
