TDC |
TDC |
Dave97 |
Dec 26 2018, 10:06 PM
Newbie Group: Members Posts: 42 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
Is there a way to figure out number 1 TDC with the engine n the car? I don't see any factory marks on either the flywheel or fan. Someone painted the fan with marks. I checked with a timing light and curve works for the Mallory distributor at idle and at 3000. I was going to pull out the distributor. Ideas?
Minerva's 914 |
Dec 26 2018, 10:18 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
Is there a way to figure out number 1 TDC with the engine n the car? I don't see any factory marks on either the flywheel or fan. Someone painted the fan with marks. I checked with a timing light and curve works for the Mallory distributor at idle and at 3000. I was going to pull out the distributor. Ideas? Best resource is @; https://www.pelicanparts.com/techarticles/9...alve_adjust.htm Copying the link is way quicker than me rewriting it here. Hope this helps |
mjrrti |
Dec 26 2018, 10:37 PM
High Desert Member Group: Members Posts: 49 Joined: 4-February 14 From: Apple Valley, Ca Member No.: 16,959 Region Association: Southern California |
Pull the plugs, follow the plug wire from #1 back to the cap and rotate the engine by hand until the rotor points at the #1 location on the cap. Look in the opening on the top and back (flywheel end) of the case. There should be a groove in the flywheel that lines with case halves where they join. That is TDC for 1 & 3. Make sure the rotor points at #1 in the dizzy and you should be there.
914 Ranch |
Dec 27 2018, 01:20 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,411 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
It is not easy to see. Everyone sees the v in the casting and thinks thats it but if you're not looking at the back side of the hole you are looking at the wrong v. There are 2 V's in that hole, one towards the front of the car and one towards the rear. It is easier to see with the engine cover off. It is almost straight down the rear of the hole.
Not that this has anything to do with this but is some funny shit. Do a search for "Chopsticks". |
Lo-Fi Version | Time is now: 10th May 2024 - 08:45 AM |
