Fuel Pump Relocation, early to late, Wiring |
Aerostatwv |
Dec 27 2018, 10:02 AM
Member Group: Members Posts: 117 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Greetings! For the folks that have moved their fuel pumps to the front of their cars, what is the best method for relocating the pump electrical wiring? I am having trouble finding a thread that addresses this. Thanks!
JFG |
Dec 27 2018, 10:49 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
i soldered onto the existing wires and ran new wire up through the tunnel and out into the under tank area.
bbrock |
Dec 27 2018, 11:33 AM
As Jeff Bowlsby pointed out to me, Porsche increased the fuel pump wire to 12 gauge when they relocated the pump. I replaced the original pump wire by running a new 12g red/blk wire from the connector on the relay board all the way to the new pump location. I also ran a new 12g brown ground wire from the left headlight ground post to the new pump location. There is a closer ground post below the air box up front but I wanted to integrate the new wire in the main harness and the left headlight bucket made more sense. It doesn't HAVE to be done that way, but that's what I did to keep the factory wiring schematic accurate and using the appropriately sized wire to accommodate the longer wire run. I had the harness out of the car though so kind of cheating.
ClayPerrine |
Dec 27 2018, 12:44 PM
Life's been good to me so far..... Group: Admin Posts: 15,450 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
As Jeff Bowlsby pointed out to me, Porsche increased the fuel pump wire to 12 gauge when they relocated the pump. I replaced the original pump wire by running a new 12g red/blk wire from the connector on the relay board all the way to the new pump location. I also ran a new 12g brown ground wire from the left headlight ground post to the new pump location. There is a closer ground post below the air box up front but I wanted to integrate the new wire in the main harness and the left headlight bucket made more sense. It doesn't HAVE to be done that way, but that's what I did to keep the factory wiring schematic accurate and using the appropriately sized wire to accommodate the longer wire run. I had the harness out of the car though so kind of cheating. (IMG:style_emoticons/default/agree.gif) I did essentially the same thing on Betty's car. I used the fuel pump wire from a 75 harness, and used the ground by the fuse box. And yes, the harness was out of the car. |
euro911 |
Dec 27 2018, 12:52 PM
I would like to do the relocation conversion on the '71, but I don't want to even think about removing the harness (IMG:style_emoticons/default/sad.gif)
I'll have to figure out another way to route the wire (IMG:style_emoticons/default/idea.gif) |
bbrock |
Dec 27 2018, 01:07 PM
I would like to do the relocation conversion on the '71, but I don't want to even think about removing the harness (IMG:style_emoticons/default/sad.gif) I'll have to figure out another way to route the wire (IMG:style_emoticons/default/idea.gif) The only serious challenge is getting the new wire through the firewall as fishing wire through the snorkel is a little bit of a challenge even with the harness out of the car. I'll bet you could do it though by popping both ends of the snorkel loose and then fishing a stiff wire through to pull the new wire through with. That's essentially how I fished the defrost harness through on mine but with the luxury of doing it on my family room floor instead of cramped under the car. Probably wouldn't be too hard with the engin out though. Of course, drilling through the firewall and installing grommets for a separate entry point would be another option. Once you are through the firewall, easy to lay a new wire parallel to the main harness all the way out to the fuel tank area. |
dr914@autoatlanta.com |
Dec 27 2018, 01:24 PM
914 Guru Group: Members Posts: 7,850 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
euro911 |
Dec 27 2018, 01:51 PM
The only serious challenge is getting the new wire through the firewall as fishing wire through the snorkel is a little bit of a challenge even with the harness out of the car. I'll bet you could do it though by popping both ends of the snorkel loose and then fishing a stiff wire through to pull the new wire through with. That's essentially how I fished the defrost harness through on mine but with the luxury of doing it on my family room floor instead of cramped under the car. Probably wouldn't be too hard with the engin out though. Of course, drilling through the firewall and installing grommets for a separate entry point would be another option. Once you are through the firewall, easy to lay a new wire parallel to the main harness all the way out to the fuel tank area. The drive train and the interior are currently out of the car, so the process should go fairly well. We'll be installing the new SS fuel lines a running the additional power conductor at the same time. |
saigon71 |
Dec 27 2018, 05:35 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I did this two winters ago. I too just soldered wires on to the existing fuel pump connection and ran them up front. I snuck the wires through the firewall through the odometer cable hole.
Pics starting on post 23 of this thread: http://www.914world.com/bbs2/index.php?sho...95025&st=20 |
Aerostatwv |
Dec 27 2018, 07:39 PM
I did this two winters ago. I too just soldered wires on to the existing fuel pump connection and ran them up front. I snuck the wires through the firewall through the odometer cable hole. Pics starting on post 23 of this thread: http://www.914world.com/bbs2/index.php?sho...95025&st=20 Bob, didn’t you have issues at Okteenerfest in NC a couple years ago? I was there and remember it. Did the relocation fix the issue? Going to Okteenerfest next fall? |
Aerostatwv |
Dec 27 2018, 07:42 PM
All great feedback! Wouldn’t have considered larger gage wire. Thank you to everyone! Will be doing this on both cars.
saigon71 |
Dec 27 2018, 08:16 PM
I did this two winters ago. I too just soldered wires on to the existing fuel pump connection and ran them up front. I snuck the wires through the firewall through the odometer cable hole. Pics starting on post 23 of this thread: http://www.914world.com/bbs2/index.php?sho...95025&st=20 Bob, didn’t you have issues at Okteenerfest in NC a couple years ago? I was there and remember it. Did the relocation fix the issue? Going to Okteenerfest next fall? Yes...that was me. My car died several times on the drive. (IMG:style_emoticons/default/sad.gif) The fuel pump relocation fixed the vapor lock issue. I may be able to make Okteenerfest next fall. Are you going? |
Aerostatwv |
Dec 28 2018, 03:06 AM
I did this two winters ago. I too just soldered wires on to the existing fuel pump connection and ran them up front. I snuck the wires through the firewall through the odometer cable hole. Pics starting on post 23 of this thread: http://www.914world.com/bbs2/index.php?sho...95025&st=20 Bob, didn’t you have issues at Okteenerfest in NC a couple years ago? I was there and remember it. Did the relocation fix the issue? Going to Okteenerfest next fall? Yes...that was me. My car died several times on the drive. (IMG:style_emoticons/default/sad.gif) The fuel pump relocation fixed the vapor lock issue. I may be able to make Okteenerfest next fall. Are you going? Yes, I want to attend. Be great to see the gang again. |
Lo-Fi Version | Time is now: 11th May 2024 - 08:57 PM |
