brake pad retainer pins |
bbrock |
Dec 27 2018, 04:54 PM
Okay, I'm tracking down missing bits for when I put my brakes back together. PET shows two part numbers for rear calipers on a four but it is leaves the difference a mystery:
901-351-913-14 is insanely expensive but available. 914-352-925-00 is NLA I'm pretty sure that the NLA pin is the one with the fat lugs that require us to drill a mount hole on modern pads to make them fit, and that the other pins could be substituted with the bonus of no longer needing to drill pads. Can anyone verify? |
914Sixer |
Dec 27 2018, 04:57 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Got a dozen or so that can be cleaned and plated. Let me know what you need. Also have some new aftermarket small pins.
bbrock |
Dec 27 2018, 05:56 PM
Got a dozen or so that can be cleaned and plated. Let me know what you need. Also have some new aftermarket small pins. I'll shoot you a PM. I'll be putting together a WTB for these and misc. other stuff so I'll try to get organized first. For pins, I need a set for one rear caliper but also need a complete set of 4 up front, plus spring spreaders, retaining clips, etc. Like I said, need to get organized. (IMG:style_emoticons/default/beerchug.gif) |
dr914@autoatlanta.com |
Dec 27 2018, 06:06 PM
914 Guru Group: Members Posts: 7,841 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you are right, but we have the kits not, both four and six
Okay, I'm tracking down missing bits for when I put my brakes back together. PET shows two part numbers for rear calipers on a four but it is leaves the difference a mystery: 901-351-913-14 is insanely expensive but available. 914-352-925-00 is NLA I'm pretty sure that the NLA pin is the one with the fat lugs that require us to drill a mount hole on modern pads to make them fit, and that the other pins could be substituted with the bonus of no longer needing to drill pads. Can anyone verify? |
JawjaPorsche |
Dec 27 2018, 06:27 PM
Pelican has a complete set with all hardware. This link for front:
https://www.pelicanparts.com/catalog/SuperC...D_pg1.htm#item3 Attached image(s) |
914Sixer |
Dec 27 2018, 08:26 PM
Be CAREFUL with the Centric hardware, half the time it is NOT correct. Kit shown is NOT correct.
bbrock |
Dec 28 2018, 09:59 AM
you are right, but we have the kits not, both four and six That's a good price compared with buying the pieces individually from Porsche. Even so, I'm a CSOB and will see what I can find used first but good to have a backup plan. I didn't see a kit for the fronts. Here's the direct link for anyone curious. (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-20845-1546012751.1.jpg) |
Dec 28 2018, 01:55 PM
front kits are commonly available and cheap there are late and early kits, and a 914-6 911t front kit
bbrock |
Dec 28 2018, 06:55 PM
front kits are commonly available and cheap there are late and early kits, and a 914-6 911t front kit Where? All I've found were Centric kits and as was already mentioned - buyer beware. (IMG:style_emoticons/default/confused24.gif) |
JawjaPorsche |
Dec 29 2018, 06:20 AM
front kits are commonly available and cheap there are late and early kits, and a 914-6 911t front kit Where? All I've found were Centric kits and as was already mentioned - buyer beware. (IMG:style_emoticons/default/confused24.gif) See above. Pelican has Bosch kits. |
bdstone914 |
Dec 29 2018, 08:31 AM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
bbrock |
Dec 29 2018, 10:08 AM
front kits are commonly available and cheap there are late and early kits, and a 914-6 911t front kit Where? All I've found were Centric kits and as was already mentioned - buyer beware. (IMG:style_emoticons/default/confused24.gif) See above. Pelican has Bosch kits. I don't really want Bosch pads so would rather find a kit for just the hardware. I'm pretty sure the hardware in that kit is Centric. Near as I can tell, the kit pictured is two hardware sets (early and late) plus some extra pieces that I don't think were on either. Kind of leary about whether I would wind up with parts I need even if I ordered it. |
Dec 29 2018, 11:08 AM
centric does not have a rear kit for the 914 just fronts and they are very cheap but not exactly like the originals but work fine
quote name='bbrock' date='Dec 29 2018, 09:08 AM' post='2677440'] [quote name='JawjaPorsche' post='2677387' date='Dec 29 2018, 05:20 AM'] [quote name='bbrock' post='2677325' date='Dec 28 2018, 07:55 PM'] [quote name='dr914@autoatlanta.com' post='2677278' date='Dec 28 2018, 12:55 PM'] front kits are commonly available and cheap there are late and early kits, and a 914-6 911t front kit [/quote] Where? All I've found were Centric kits and as was already mentioned - buyer beware. (IMG:style_emoticons/default/confused24.gif) [/quote] See above. Pelican has Bosch kits. [/quote] I don't really want Bosch pads so would rather find a kit for just the hardware. I'm pretty sure the hardware in that kit is Centric. Near as I can tell, the kit pictured is two hardware sets (early and late) plus some extra pieces that I don't think were on either. Kind of leary about whether I would wind up with parts I need even if I ordered it. [/quote] |
tomeric914 |
Dec 29 2018, 05:09 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Paging @Eric_Shea
Lo-Fi Version | Time is now: 9th May 2024 - 02:28 PM |
