Where to put oil temp sender |
bmurphy210 |
Dec 28 2018, 07:51 PM
Newbie Group: Members Posts: 6 Joined: 18-September 15 From: Holly MI Member No.: 19,175 Region Association: Upper MidWest |
My 70 1.7 has grown to 2366cc, so I want to add an oil temp sender. I've already got the sender and the gauge. The only place I can see to put it is where the drain plug is now. I thought about removing the taco plate and welding a bung into it, but after a lot of work, it would still be about the same distance from the road surface. I could tee off the pressure sensor by the distributor, but I don't know how hard it will be to find a metric tee. Any suggestions?
Thanks, Brian |
Dec 28 2018, 08:02 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My 70 1.7 has grown to 2366cc, so I want to add an oil temp sender. I've already got the sender and the gauge. The only place I can see to put it is where the drain plug is now. I thought about removing the taco plate and welding a bung into it, but after a lot of work, it would still be about the same distance from the road surface. I could tee off the pressure sensor by the distributor, but I don't know how hard it will be to find a metric tee. Any suggestions? You need an actual taco plate. What you have right now is just a cover. The real taco plate has the bung/threads for the sender. (IMG:style_emoticons/default/shades.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1546048960.1.jpg) |
bmurphy210 |
Dec 29 2018, 08:03 AM
My 70 1.7 has grown to 2366cc, so I want to add an oil temp sender. I've already got the sender and the gauge. The only place I can see to put it is where the drain plug is now. I thought about removing the taco plate and welding a bung into it, but after a lot of work, it would still be about the same distance from the road surface. I could tee off the pressure sensor by the distributor, but I don't know how hard it will be to find a metric tee. Any suggestions? Thanks, Brian Thanks! Brian |
Lo-Fi Version | Time is now: 10th May 2024 - 08:10 AM |
