Car Won't Start |
Car Won't Start |
mmascari |
Dec 29 2018, 04:42 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I let my car sit in a storage unit only for a couple weeks and I went over and it won't start. It ran fine when I dropped it off. It is a 3.0l six with PMO carbs. The last time I let it sit for a while I had to dump gas directly into the carbs. I tried that again this time but no luck. Any other ideas on how to get it fired up?
Dec 29 2018, 04:43 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
See if it runs on starter fluid.
mmascari |
Dec 29 2018, 04:50 PM
Dec 29 2018, 05:32 PM
Fuel does not last.
Dump the fuel, change the filter. You may also need to clean out the bowls of the carbs. I would suggest you put a physical shut off in the fuel line prior to the filter, then when you go to store it, shut the fuel off while it’s running and let the motor suck out the line and carbs till it dies. Typical old car storage technique to keep carbs clean . |
Lo-Fi Version | Time is now: 12th May 2024 - 02:48 AM |
