Center High mounted Brake Light, any new attempts |
malcolm2 |
Jan 3 2019, 01:33 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have been thinking about the subject. There are only about 3 Topic Titles that pop up on a search. So I am curious if folks are doing this.
I notice lots of pick-up trucks with LED strips under the tail gate. Maybe only $20 and you get blinkers (and hazards), brake lights, and reverse lights. Plus the unwanted running lights. The 1st few I saw on Amazon used a trailer wiring couple, so that would be easy. Summit Racing has one for $30 but it is 60" long. Probably too long, wonder if I could just go with 1/2 of it and skip the blinker function too? SUMMIT RACING LINK Thoughts?? |
Tom_T |
Jan 3 2019, 02:44 PM
Malcolm -
These will work on a 914 too - easy install & easily removable too. https://www.gowesty.com/product-details.php?v=&id=23669 I have it on my 88 Westy van, & may do it on my 914 later on. .... not my van (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
oakdalecurtis |
Jan 3 2019, 04:22 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
A couple of thoughts. I added a third brake light under the targa bar. I would be cautious about using any LED light here that you can see from inside the cabin at night when activated, otherwise you'll get a lot of distracting reflection in the rear window. I did not want to rely on the light's adhesive so I drilled a small hole through the curved mount and put a metal screw up into the targa bar on each end. I ran the wires through the attachment leg into a small hole in the targa bar, then out the back and along under the rear trim piece. Where the trim meets the body, I put the wire through a small hole drilled through the body under the trim, then through the engine bag into the trunk through another small hole. Once inside the trunk, the wire went back to the brake light wires at the rear lens.
This light does not inhibit your rear view in your mirror, as it is very high up in the mirror's field of view. I also added a small strobe module at the brake light wire connection, so when I hit my brakes, the third light strobes nicely, hard to miss! When I took a video of the third brake light working at night, you could see the LED strobe come on a moment BEFORE the incandescent lights could heat up and shine. Good luck! |
burton73 |
Jan 3 2019, 05:42 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
With all the big trucks in Nashville I do not blame you as our cars are really small.
There is a chip or something that make the brake lights into a strobe. I think I will do something like that on my 6 as with desecrated drivers it is just too easy to get hit. Cell phones and texting is a real problem. Bob B (IMG:style_emoticons/default/sheeplove.gif) we are the sheep in the battle with traffic |
burton73 |
Jan 3 2019, 05:45 PM
With
malcolm2 |
Jan 3 2019, 08:45 PM
With all the big trucks in Nashville I do not blame you as our cars are really small. There is a chip or something that make the brake lights into a strobe. I think I will do something like that on my 6 as with desecrated drivers it is just too easy to get hit. Cell phones and texting is a real problem. Bob B (IMG:style_emoticons/default/sheeplove.gif) we are the sheep in the battle with traffic I saw the flash module on another post. I think it was some engineering students at univ of Tenn that had something to do with inventing a bulb that flashes 3 times then stays bright. I also noticed that there are aftermarket LED fixtures for motorcycles that strobe. No mofule needed. |
malcolm2 |
Jan 3 2019, 08:46 PM
Damn iphone double post.
oakdalecurtis |
Jan 3 2019, 09:04 PM
Here’s the strobe module I used. Five dollars, easy to install, works beautifully! This one is for LED lights, but it’s easy to find one for seventeen dollars that works with incandescent lights if you want. (IMG:style_emoticons/default/beerchug.gif)
https://www.superbrightleds.com/moreinfo/st...ASABEgKB1fD_BwE |
malcolm2 |
Jan 3 2019, 09:13 PM
Malcolm - These will work on a 914 too - easy install & easily removable too. https://www.gowesty.com/product-details.php?v=&id=23669 I have it on my 88 Westy van, & may do it on my 914 later on. .... not my van (IMG:style_emoticons/default/beerchug.gif) Tom /////// So you stick it to the inside of the window? Might be a good way to do it. |
RickS |
Jan 3 2019, 10:34 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
I used double sided tape to attach mine to the underside of the targa bar. It flashes three times and goes solid. Bought it from Custom Dynamics on line. Originally designed for bikes. I ran the wires under the chrome trim to the engine compartment and into the trunk where I tapped into the tail lights. There is zero reflection on the rear window or in the cabin.
JP3 |
Jan 4 2019, 06:18 AM
Jerry Group: Members Posts: 61 Joined: 6-August 15 From: New Lenox, IL Member No.: 19,035 Region Association: None |
Mark Henry |
Jan 4 2019, 07:47 AM
There is a chip or something that make the brake lights into a strobe. I think I will do something like that on my 6 as with desecrated drivers it is just too easy to get hit. Cell phones and texting is a real problem. Bob B (IMG:style_emoticons/default/sheeplove.gif) we are the sheep in the battle with traffic I have one on my bug, 4 fast flashes, 4 slow flashes then on steady. It's only on the 3rd brake light itself. I have another module for my 914, I was going to use a corvette 3rd brake light housing but I now have a GT lid, so I'm watching this thread for other options. Distracted driving (cell phone, etc.) here is now a $1000 fine, a three-day licence suspension and three demerit points. That's the first offence, 2nd offence within 5 years of the 1st the fine rises to $2,000, plus six demerit points and a seven-day driver's licence suspension. Third is $3000, six demerit points and plus a 30 day suspension. |
amfab |
Jan 4 2019, 08:35 AM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
I did one as a narrow slot in the aluminum trim at the back of the Targa bar that worked well and was difficult to see when off. I don't have any photos with me. I can take a picture when I am back from vacation next week. Essentially it was an1/8th inch slot about seven inches long that I cut down the center of the trim with a cutoff tool that followed the slight curve of the targa bar trim.
I then took an LED strip light and taped it inside the trim with aluminum tape and snapped the trim back on. I got one of those connector tab splitter things and ran a wire from the drivers taillight up the loom and out though the outer edge of the engine grill to up under the sail trim to get to the top trim. you can't see the wire from the outside if you get it far enough over. -Andrew |
malcolm2 |
Jan 4 2019, 10:59 AM
I like the idea of the Center Brake light being as high as possible. So stick on, the underside of the targa bar, or maybe the targa rear edge.
I am not 100% sold on the 3m adhesive route, but I bought me the Go Westy rig. It looks like it will not reflect back into the cock-pit. I suppose I can find the brake wire that is inside or it looks like there is enough wire to run it to the rear trunk and do the spade connection. The Strobe Module looks like a must have. Gonna get one of those too. I figured if I don't like it, I can install it on my 72 VW bus. And if I do like it, I can buy another. If I could figure out the best way to mount it and the unit was not too long, I still like the idea of using those pick-up truck tailgate lights. They are cheap, I might get one and play with it too. I'll add some photos when I start working on it. |
GeorgeRud |
Jan 4 2019, 11:07 AM
There was a fellow in the Midwest that mounted a brake light from a Ford GT into a slot cut into the rear targa trim bar that looked great. Maybe one of the Midwest contingent has a photo they could share, but it was way before digital photography.
Jacob |
Jan 4 2019, 11:22 AM
Member Group: Members Posts: 131 Joined: 12-February 08 From: Mansfield, Oh Member No.: 8,705 Region Association: Upper MidWest |
There was a fellow in the Midwest that mounted a brake light from a Ford GT into a slot cut into the rear targa trim bar that looked great. Maybe one of the Midwest contingent has a photo they could share, but it was way before digital photography. I think I found it here: http://www.914world.com/bbs2/index.php?sho...28853&st=20 Attached image(s) |
Mark Henry |
Jan 4 2019, 12:49 PM
GeorgeRud |
Jan 4 2019, 01:54 PM
Yes, Jacob found a picture of the installation. By far the cleanest and most correct appearing method I’ve ever seen. Plus, you should see the looks at the Ford Parts counter when you stroll 8n asking for a high mounted brake light for a Ford GT. Supposedly it was also used on a Taurus SHO, but I’m sure other LED lights would als9 work.
mb911 |
Jan 4 2019, 02:05 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
That looks perfect.
Ferg |
Jan 4 2019, 02:59 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I bought two of these for the rear of my Hitch mountain bike rack. Wired them up for blinkers brake ect.
https://www.amazon.com/Wiipro-Universal-Dav...rake+motorcycle I've been happy with them so far, and they are by far the smallest that are suitable for outside use that I have seen. I think I may order another and hide it in the engine grill as I don't want it seen. They put out a really bright red and should light up really well. I don't think I'd use the blinker ect in this application though. |
Lo-Fi Version | Time is now: 16th May 2024 - 06:23 AM |
