First/revers idler gear condition, What say the transmission experts? |
draganc |
Jan 8 2019, 12:07 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi folks!
I’m “freshing” up my transmission that came with my car - I have no idea about it’s condition. Hence, I bought Dr. Evil’s dvd and took the whole shebang a part for inspection. Surprisingly gears 2-5 look very good and it appears that the rings have been replaced and the dog teeth look nice and pointy. The only worn part appears to be the 1/R idler gear, strangely in the middle (yellow circle) and the green areas?!?! Is this normal? I have a spare idler gear with matching 1/R I’m contemplating to swap. Thanks for the groups feedback! (IMG:style_emoticons/default/beerchug.gif) dc PS: the pics were taken before the cleaning. Came out nice and clean. PPS: any suggestions where to buy the thrust and needle bearings? |
dr914@autoatlanta.com |
Jan 8 2019, 08:34 AM
914 Guru Group: Members Posts: 7,873 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
if any question you can buy a perfect used one for 25 bucks
Hi folks! I’m “freshing” up my transmission that came with my car - I have no idea about it’s condition. Hence, I bought Dr. Evil’s dvd and took the whole shebang a part for inspection. Surprisingly gears 2-5 look very good and it appears that the rings have been replaced and the dog teeth look nice and pointy. The only worn part appears to be the 1/R idler gear, strangely in the middle (yellow circle) and the green areas?!?! Is this normal? I have a spare idler gear with matching 1/R I’m contemplating to swap. Thanks for the groups feedback! (IMG:style_emoticons/default/beerchug.gif) dc PS: the pics were taken before the cleaning. Came out nice and clean. PPS: any suggestions where to buy the thrust and needle bearings? |
draganc |
Jan 8 2019, 01:16 PM
if any question you can buy a perfect used one for 25 bucks George, Thanks for the tip! I thought the idler and the first/revers gears are a matching set. Is it ok to replace just the idler without the other two or were you referring the $25 for all three gears? Regards, dc PS: do you have them in your web store? How about those new thrust and needle bearings? |
Lo-Fi Version | Time is now: 26th May 2024 - 05:54 PM |
