Portable tire inflator recommendation |
zaballosc |
Jan 8 2019, 09:24 AM
Newbie Group: Members Posts: 19 Joined: 31-August 15 From: Whitewater, WI Member No.: 19,118 Region Association: Upper MidWest |
Hi, I was wondering if anyone had any recommendations for portable tire inflators. I'm looking for one for my 2002 and for my 914, but I want to make sure that I get a dependable model. Any thoughts? Thanks!
mgphoto |
Jan 8 2019, 09:37 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Later model Porsches use a collapsible spare which must be inflated, find a Porsche parts recycler they will have a good selection of inflation units priced around $100
Mark Henry |
Jan 8 2019, 09:52 AM
Later model Porsches use a collapsible spare which must be inflated, find a Porsche parts recycler they will have a good selection of inflation units priced around $100 For a Porsche pump in a case 10 years ago you could get them for $100...good luck now days. You can get a cheap china pump off of amazon, I just check out the amazon and YT reviews to try to find the kit others have had good luck with. I have't a clue about soldering irons, checked out amazon and YT reviews and ended up with a $100 Hakko. In 5 minutes found out Hakko was a good name, watched a YT shoot out vid and bought it. Not top of the line, but 0 to 750F in 10-15 seconds works for me. |
bbrock |
Jan 8 2019, 10:42 AM
I have't a clue about soldering irons, checked out amazon and YT reviews and ended up with a $100 Hakko. In 5 minutes found out Hakko was a good name, watched a YT shoot out vid and bought it. Not top of the line, but 0 to 750F in 10-15 seconds works for me. I did exactly the same and love that soldering iron. Sorry for the hijack. Now back to the regularly scheduled program. (IMG:style_emoticons/default/popcorn[1].gif) |
tmc914 |
Jan 8 2019, 07:10 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
Hi, I was wondering if anyone had any recommendations for portable tire inflators. I'm looking for one for my 2002 and for my 914, but I want to make sure that I get a dependable model. Any thoughts? Thanks! What I use is the Kobalt KLDP1. It works via the cigarette lighter 12VDC or you can plug into 120 volts. It is not heavy duty for only about $50 bucks. I use it to top off tire air pressure. If you let it run for more than 10 minutes it stops to cool down. Only takes a couple minutes to top off each tire. Can be bought at Lowes. Hope this helps. |
Valy |
Jan 8 2019, 09:57 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I like this. Good for topping air and also fixing a small puncture.
I hate replacing wheels on the road. This kit works wonders. https://www.amazon.com/Slime-50107-Smart-Em...DAN7T4JAAFM69YA |
Gary |
Jan 9 2019, 05:05 AM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
We bought this one a few years back. Works for all the vehicles and does the bike tires too: Viair 00073 70P Heavy Duty Portable Compressor.
Andyrew |
Jan 9 2019, 09:43 AM
I carry the Ryobi 18v inflator with me now for track days and in my daily with a patch kit in a small bag. I top off the battery every 6 months or so.
burton73 |
Jan 9 2019, 11:12 AM
burton73 Group: Members Posts: 3,515 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I use the Porsche air inflator kit like the ones that came in my 86 Carrera. I bought a couple of them 10 years ago and the price is lower now. This one is on Ebay for $280. And it has all the cover clamps and accessories to fill up your basketball. If clamp is missing they are less Looks cool and I like that but it is not cheap. You can get a Tesla one with the goop for $50. New
Never use the goop unless you are going to get your tire fixed right away as it needs to get cleaned out after you use it Bob B |
iamchappy |
Jan 9 2019, 12:32 PM
douglastic |
Jan 9 2019, 02:20 PM
not a real person Group: Members Posts: 58 Joined: 7-November 16 From: Beaumont, CA Member No.: 20,566 Region Association: Southwest Region |
I got the Viair 00088 88P Portable Air Compressor for our LR3
Reasons: Does larger tires (faster, more powerful), more PSI/CFM (45% duty cycle = longer life), and no cigarette plug (no under-rated fuse problems) Great specs for under $60 |
Amphicar770 |
Jan 9 2019, 03:04 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
The Kobalt unit at Lowe's is highly rated and got a popular mechanics top pick. What's nice about it is that it runs either 120v AC or 12v plug in. Inflates pretty quickly.
https://www.lowes.com/pd/Kobalt-12-Volt-120...ator/1000092575 |
zaballosc |
Jan 9 2019, 06:39 PM
Wow, thank you for all of the suggestions! I'm going to take a look at used Porsche pumps, but if that doesn't work out you all have provided me with some great alternatives. Thanks again!
Andyrew |
Jan 9 2019, 08:48 PM
I carry the Ryobi 18v inflator with me now for track days and in my daily with a patch kit in a small bag. I top off the battery every 6 months or so. Thats what i use also, have the impact wrench along with it. The half inch impact is my favorite tool I own! |
Lo-Fi Version | Time is now: 9th May 2024 - 04:31 PM |
