Best rear wheel/stub axle bearing, Bearing renew. |
914Toy |
Jan 8 2019, 12:39 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
What is recommended choice here for trailing arm rear wheel/stub axle bearing - there are two available at Pelican Parts: FAG @ $37.50 with four star rating and SKF @ $75.00 with three star rating?
Mark Henry |
Jan 16 2019, 03:34 PM
How cold is your freezer? I have one that runs about -30 (IMG:style_emoticons/default/smile.gif)
As long as it's been in say 12 hours and the hole is well cleaned out I don't have much issue. Maye some light tapping with a drift or I jury rig a length of threaded rod to pull it in. but yeh... you're always going to run into that boitch, guess I've been lucky, I should be, because I've ran into my fair share of fuchery with other poop. (IMG:style_emoticons/default/rolleyes.gif) |
BeatNavy |
Jan 16 2019, 04:05 PM
Apparently not Ontario cold! (IMG:style_emoticons/default/biggrin.gif) |
Mark Henry |
Jan 16 2019, 08:28 PM
Coldest day I've seen here was -35...the day I moved into this house. (IMG:style_emoticons/default/dry.gif) Normal temps are around 15-32F this time of year, I don't care as my shop has good heat. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:40 PM |
