FYI: Reproduction Parts, Worth Checking Out |
914Sixer |
Jan 13 2019, 12:47 PM
914 Guru Group: Members Posts: 8,878 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Here is a couple of items that I was in need of and I found them. Curved late fuel injector hoses and oil temp sender seal. There is a lot of good stuff in one place for quick reference. Just trying to help fellow teeners.
http://914Reproductionparts.com Attached image(s) |
Jan 13 2019, 01:39 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
No favors here -
REBUILT TRANSMISSION; 914 1973-76 - $2,500.00 Our rebuilt transaxles are completely dismantled and cleaned. The synchros, seals gaskets and all questionable or worn parts are replaced. These transaxles are covered with our six month/six thousand mile warranty against internal breakage. There is a core charge, which is refundable upon receiving your rebuildable part. Please do not expect the complete core charge to be refunded as 914 gear boxes these days need many more parts than the rebuild charge covers. Full/complete. Yes, the core charge is $1,000 in addition to the $2.5K with no guarantee of a refund. I had a feeling I knew who it was even before I clicked - Add to cart. (IMG:style_emoticons/default/shades.gif) Usually when you use a combination of new and good used parts, it's called refreshed. A rebuild is usually all new. |
Steve |
Jan 13 2019, 01:52 PM
914 Guru Group: Members Posts: 5,582 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I thought the pictures looked familiar.
rhodyguy |
Jan 13 2019, 01:57 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Perculiar. AA?
Steve |
Jan 13 2019, 02:02 PM
rhodyguy |
Jan 13 2019, 02:06 PM
I didn't get that far. The disclaimer on the transmission build is quite the read. Pricing? Seems like it pretty much means nothing
mb911 |
Jan 13 2019, 03:16 PM
914 Guru Group: Members Posts: 6,841 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Some of it looks like 914 rubber and some AA
914Sixer |
Jan 13 2019, 06:13 PM
Tried to make it NOT a political topic. Just parts.
Steve |
Jan 13 2019, 06:23 PM
Tried to make it NOT political topic. Just parts. I have nothing against AA. Kind of nice they now have a web site specific to the 914. I am also always curious on price versus quality and fitment on after market parts. Hard to get a straight answer before it turns into a flame war. |
mb911 |
Jan 13 2019, 08:05 PM
I think it is well put together.
Mikey914 |
Jan 14 2019, 01:18 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Well we have made one of the parts in question and will be doing a GB on it shortly.
Not just a copy of the original but an improvement. Here is the oil pressure sender boot (top of engine tin). You can see why this stays in the hole better. Attached thumbnail(s) |
Mikey914 |
Jan 14 2019, 01:22 PM
Installed
Note we are starting to mark our parts so you can identify origin (IMG:style_emoticons/default/biggrin.gif) The irregular shape of the hole makes fitment a challenge. Attached thumbnail(s) |
dr914@autoatlanta.com |
Jan 14 2019, 01:30 PM
914 Guru Group: Members Posts: 7,846 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no one uses all new parts when rebuilding a transmission ask dr evil, he is the authority. Syncros sliders dog teeth gasket seal kit and bearings, hopefully nothing else is bad
No favors here - REBUILT TRANSMISSION; 914 1973-76 - $2,500.00 Our rebuilt transaxles are completely dismantled and cleaned. The synchros, seals gaskets and all questionable or worn parts are replaced. These transaxles are covered with our six month/six thousand mile warranty against internal breakage. There is a core charge, which is refundable upon receiving your rebuildable part. Please do not expect the complete core charge to be refunded as 914 gear boxes these days need many more parts than the rebuild charge covers. Full/complete. Yes, the core charge is $1,000 in addition to the $2.5K with no guarantee of a refund. I had a feeling I knew who it was even before I clicked - Add to cart. (IMG:style_emoticons/default/shades.gif) Usually when you use a combination of new and good used parts, it's called refreshed. A rebuild is usually all new. |
Jan 14 2019, 01:31 PM
Jan 14 2019, 02:40 PM
no one uses all new parts when rebuilding a transmission ask dr evil, he is the authority. Syncros sliders dog teeth gasket seal kit and bearings, hopefully nothing else is bad No favors here - REBUILT TRANSMISSION; 914 1973-76 - $2,500.00 Our rebuilt transaxles are completely dismantled and cleaned. The synchros, seals gaskets and all questionable or worn parts are replaced. These transaxles are covered with our six month/six thousand mile warranty against internal breakage. There is a core charge, which is refundable upon receiving your rebuildable part. Please do not expect the complete core charge to be refunded as 914 gear boxes these days need many more parts than the rebuild charge covers. Full/complete. Yes, the core charge is $1,000 in addition to the $2.5K with no guarantee of a refund. I had a feeling I knew who it was even before I clicked - Add to cart. (IMG:style_emoticons/default/shades.gif) Usually when you use a combination of new and good used parts, it's called refreshed. A rebuild is usually all new. Yes, Mike is very good and often uses good used parts but his rebuilds are way less expensive. Many shops do build with only new and for $2,500 - 3,500, I would be disappointed to get used gears that already have 50-100K on them. |
Lo-Fi Version | Time is now: 11th May 2024 - 10:44 AM |
