Sidepanels, olor code |
Perobye |
Jan 15 2019, 04:27 AM
Newbie Group: Members Posts: 2 Joined: 31-May 15 From: norway Member No.: 18,780 Region Association: None |
Hello
Does anyone know the colorcode for the side panels and guarpanels front and back on 1973 mod ? |
Dion |
Jan 15 2019, 07:17 AM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Language barrrier? Front & rear wings/quarter panels? Or interior pieces? Are you referring to the colour code of your 914?
There will be a tag on the drivers front door jamb/closing panel. Little black tag with “Karmann” stamped on it the colour code is on that tag. (IMG:style_emoticons/default/welcome.png) Attached image(s) |
Jan 15 2019, 07:26 AM
914-6 GT in waiting Group: Members Posts: 19,261 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I think he is referring to rocker panels and F & R valance.
(IMG:style_emoticons/default/welcome.png) |
Dion |
Jan 15 2019, 08:04 AM
Good point Mark, now that I reread it a couple of times.
On that regard , not being a concours fella, I’d be going with a satin black. I’m sure there are plenty of appropriate colour codes and manufacturers for that proper sheen of black. Carry on... |
dr914@autoatlanta.com |
Jan 15 2019, 09:32 AM
914 Guru Group: Members Posts: 7,850 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Wurth makes a good satin black trim paint. Important for it to be trim paint as it is flexible, and goes on to provide the original orange peel type finish
TravisNeff |
Jan 15 2019, 09:34 AM
can you get that in sprayable vs rattle can?
mgphoto |
Jan 15 2019, 10:24 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
As per the factory repair manual:
PAINTING DULL BLACK PARTS General The fiberglass roof, front and rear bumpers (beginning with 1973 models, except cars built to USA specifications), front and rear panels and outer covers of the rocker panels are painted a dull black. If repairing becomes necessary use domestically supplied paints, such as Rinshed - Mason Nr. 681 Black or equivalent. Volume #8 Page 22.1-1/2 I used a hot rod flat black, applied heavy, takes on a sheen and the slight orange peel effect. |
DickSteinkamp |
Jan 15 2019, 02:25 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
can you get that in sprayable vs rattle can? SEM Trim Black comes in quarts... SEM Trim Black (IMG:http://www.914world.com/bbs2/uploads_offsite/www.semproducts.com-20876-1547583956.1.png) |
Tom_T |
Jan 15 2019, 04:54 PM
can you get that in sprayable vs rattle can? Yes, AFAIK Wurth still sells it in quarts &/or gallons. You can also use their underbody Schutz for the orange peel/pebbly surface, with satin or dull black over (e.g.: matte or semi-matte, etc.). Great Factory Repair Manual quote by mgphoto, since Porsche even back then recommended finding local paints, rather than German Sikkends, Galsurit, or whatever they were using at the time. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Mikey914 |
Jan 17 2019, 03:27 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Actually matched it and provide in 6 or 16 oz cans. In a Delstar enamel. Same color for the grill so when we made the letters we made available as a kit or alone. You can find here
https://shop.914rubber.com/Deck-Lid-Grille-...m?categoryId=-1 Attached image(s) |
Perobye |
Jan 20 2019, 07:19 AM
Actually matched it and provide in 6 or 16 oz cans. In a Delstar enamel. Same color for the grill so when we made the letters we made available as a kit or alone. You can find here https://shop.914rubber.com/Deck-Lid-Grille-...m?categoryId=-1 Thank you |
Lo-Fi Version | Time is now: 12th May 2024 - 12:15 PM |
