70 914-6, fresh air blower motor |
huck914-6 |
Jan 15 2019, 03:10 PM
Newbie Group: Members Posts: 1 Joined: 15-January 19 From: idaho Member No.: 22,803 Region Association: Pacific Northwest |
hey guys first post here.
so im currently in the middle of doing the front fresh air blower motor and I bought the bosch replacement motor. my problem is I cant get the new motor down into the housing far enough to engage the spring clips to hold it in place. has anyone ever done just the motor replacement? |
914Sixer |
Jan 15 2019, 03:42 PM
Pictures would help
burton73 |
Jan 15 2019, 04:00 PM
burton73 Group: Members Posts: 3,520 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Retroracer |
Jan 15 2019, 08:54 PM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
hey guys first post here. so im currently in the middle of doing the front fresh air blower motor and I bought the bosch replacement motor. my problem is I cant get the new motor down into the housing far enough to engage the spring clips to hold it in place. has anyone ever done just the motor replacement? Hey, welcome to the world! I did the motor replacement thing about 3 years ago, and recall having to, ah, gently modify the replacement motor to fit. I vaguely recall having to cut some extraneous lugs or mounting tabs off? Compare and contrast the old and new motors carefully to see the differences - calipers can help here - and good luck. Looking back, I took photos of the old motor and wiring, but sadly not of the shiny replacement - so no help posting those here. Be good to have that info documented on the site. - Tony |
UROpartsman |
Jan 17 2019, 04:39 PM
Member Group: Members Posts: 291 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
We just released complete Blower Motor assembly 911 571 320 32, so folks will no longer have to hassle with modifying motors to make it work. Here's the announcement: http://www.914world.com/bbs2/index.php?act...=4&t=335661
Attached thumbnail(s) |
bdstone914 |
Jan 18 2019, 09:56 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
We just released complete Blower Motor assembly 911 571 320 32, so folks will no longer have to hassle with modifying motors to make it work. Here's the announcement: http://www.914world.com/bbs2/index.php?act...=4&t=335661 @UROpartsman The fan blade is a different design than OEM. 1. Have you tested it for CFM airflow? 2. Are the blades balanced like OEM? See the wire clips used by the factory ? 3. Has it been test fitted into a 914 fan housing? Attached thumbnail(s) |
UROpartsman |
Jan 18 2019, 11:24 AM
Here's current OEM, our fan is the same shape: https://www.pelicanparts.com/More_Info/911-...SVSVSI=0807.htm
Will check with engineering for answers to the other questions. |
bdstone914 |
Jan 18 2019, 07:22 PM
Here's current OEM, our fan is the same shape: https://www.pelicanparts.com/More_Info/911-...SVSVSI=0807.htm Will check with engineering for answers to the other questions. Looks like the OEM and your part is identical. Looks like you are sourcing from the same place Porsche gets theirs. I got a URO brake switch and a Genuine Porsche. Made on the same tooling from the stamping marks. Only difference was Porsche part had the part number ink jetted on the part. |
worn |
Jan 19 2019, 08:04 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Here's current OEM, our fan is the same shape: https://www.pelicanparts.com/More_Info/911-...SVSVSI=0807.htm Will check with engineering for answers to the other questions. Looks like the OEM and your part is identical. Looks like you are sourcing from the same place Porsche gets theirs. I got a URO brake switch and a Genuine Porsche. Made on the same tooling from the stamping marks. Only difference was Porsche part had the part number ink jetted on the part. Looks like a win win if the producer goes to the trouble of balancing and due diligence in test fitting. If they were to do that we would win and they would get chops for doing it right. |
UROpartsman |
Jan 21 2019, 04:34 PM
Just got word from engineering:
Lo-Fi Version | Time is now: 13th May 2024 - 02:13 PM |
