Jan 15th is officially turd day Event 2., Clutch cable tube is broken in the front of the tunnel. |
buck toenges |
Jan 15 2019, 05:45 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
So for the second part of turd day I was installing a clutch cable and side shift shifter into my '72 914. The shifter was hitting the clutch cable tube and I couldn't get really good shifts going. I found out the clutch cable tube was not welded to the tunnel in the front. The tube ends about 3-4 inches in front of the front end of the shifter hole in the tunnel. I need to nail it down. I played with the clutch pedal to see where the cable interacted with the tube. It seemed like the tube should be close to the top of the tunnel as there was less noise from the cable moving in the tube.
I could drill a small hole into the tunnel and tack weld the tube to the driver side of the tunnel. Brad Mayeur said he uses a little u-bolt some time to attach and secure the tube to the tunnel wall. My question is where should the tube be located in the tunnel. Should it be placed a certain way so the side shift shift rod and shifter doesn't get all jammed up. Is there an issue with side shift rods and shifters in the tunnel when using in an earlier car? Thanks, Buck |
76-914 |
Jan 15 2019, 08:39 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You can pull it up against the tunnel wall. You can use a uBolt. The factory didn't weld the clutch tube; they brazed it. If your clutch tube gets a glob of slag in the tube a new cable won't pass. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 10th May 2024 - 08:10 AM |
