Giving Up On Vacuum Advance |
Ansbacher |
Jan 18 2019, 06:22 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Car = '74 2.0 Liter, Dual Dellorto Carbs
For years I have been 'adequately" running an 009 mechanical only distributor. Finally took the pervasive advice out there to go with a vacuum advance dizzy from a 1.8L 914. Since only one of my Dellorto carbs had an existing vacuum port (ported type), I had to drill a port in my other one (no problem there). I used good quality anti-pulse valves in the lines and measured a maximum vacuum of 12 inches of mercury with partial throttle. Installed the 1.8 dizzy and set the timing, first without the vacuum lines attached. To satisfy my usual 30-32 degrees at 3500 RPM, the idle timing had to be at about 5-6 degrees (quite low for my setup which is happier at about 10 degrees. When I attached the vacuum lines my timing at 3500 RPM went sky high into the 40s. This seems way too high. Is this normal? Overall, I found the car to run better without the vacuum attached and the carbs plugged off. Am I doing something wrong here? I don't like the numbers I am getting. Everyone said this was the way to go with carbs, but I am not seeing results. Advice appreciated. Ansbacher |
porschetub |
Jan 19 2019, 08:14 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
My research indicated the anti pulse valve is only required if you only have one vacuum pickup,have you tried 2 vacuum lines from both carbs with a tee fitting to a single line on the distributor ?,the distributor will only advance to the range the vacuum unit was designed for so this seems strange you have this situation ,the advance place will only allow movement it its range also.
The so called SVDA used on 1600 beetles appears to work well on stock cam motors,and there is the Chinese repop which appears to be designed off the same unit,I have one of each and the repop one seems to be made well enough however don't think they will last as well as the originals (IMG:style_emoticons/default/confused24.gif) . |
Lo-Fi Version | Time is now: 25th May 2024 - 08:59 PM |
