Giving Up On Vacuum Advance |
Ansbacher |
Jan 18 2019, 06:22 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Car = '74 2.0 Liter, Dual Dellorto Carbs
For years I have been 'adequately" running an 009 mechanical only distributor. Finally took the pervasive advice out there to go with a vacuum advance dizzy from a 1.8L 914. Since only one of my Dellorto carbs had an existing vacuum port (ported type), I had to drill a port in my other one (no problem there). I used good quality anti-pulse valves in the lines and measured a maximum vacuum of 12 inches of mercury with partial throttle. Installed the 1.8 dizzy and set the timing, first without the vacuum lines attached. To satisfy my usual 30-32 degrees at 3500 RPM, the idle timing had to be at about 5-6 degrees (quite low for my setup which is happier at about 10 degrees. When I attached the vacuum lines my timing at 3500 RPM went sky high into the 40s. This seems way too high. Is this normal? Overall, I found the car to run better without the vacuum attached and the carbs plugged off. Am I doing something wrong here? I don't like the numbers I am getting. Everyone said this was the way to go with carbs, but I am not seeing results. Advice appreciated. Ansbacher |
cgnj |
Jan 19 2019, 10:10 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
How much vacuum @ idle? How much @ 3k?
7.5 degrees @ 800-900 rpm would be correct. I think you are in the ballpark. High vacuum, low load you want to advance to increase mpg. The 10 degrees advance with the 009 is immaterial. It is compensation for the short curve. |
Ansbacher |
Jan 19 2019, 03:05 PM
How much vacuum @ idle? How much @ 3k? 7.5 degrees @ 800-900 rpm would be correct. I think you are in the ballpark. High vacuum, low load you want to advance to increase mpg. The 10 degrees advance with the 009 is immaterial. It is compensation for the short curve. Since I am using ported vacuum, I have 0 vacuum at idle. It doesn't kick in until the butterfly starts to open (as it should). At 3K I have 12 inches HG. The car is much more responsive on pull out when the idle timing is above 8 or so degrees. With this distributor I can't keep it under my target 32 degrees at 3500 RPM when I set idle to anything above 5 degrees, and that is WITHOUT vacuum hooked up. Add the vacuum and it really goes off the chart, I lose power, and it starts to ping when I tromp on it. This is my dilemma. Ansbacher |
tmessenger |
Jan 20 2019, 09:50 AM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
Mechanical advance springs fatigue with age, with weak springs the full mechanical advance comes to quickly at a lower RPM. Have you checked the curve to see if the mechanical advance is correct?
Tim How much vacuum @ idle? How much @ 3k? 7.5 degrees @ 800-900 rpm would be correct. I think you are in the ballpark. High vacuum, low load you want to advance to increase mpg. The 10 degrees advance with the 009 is immaterial. It is compensation for the short curve. Since I am using ported vacuum, I have 0 vacuum at idle. It doesn't kick in until the butterfly starts to open (as it should). At 3K I have 12 inches HG. The car is much more responsive on pull out when the idle timing is above 8 or so degrees. With this distributor I can't keep it under my target 32 degrees at 3500 RPM when I set idle to anything above 5 degrees, and that is WITHOUT vacuum hooked up. Add the vacuum and it really goes off the chart, I lose power, and it starts to ping when I tromp on it. This is my dilemma. Ansbacher |
Lo-Fi Version | Time is now: 25th May 2024 - 09:00 PM |
