Giving Up On Vacuum Advance |
Ansbacher |
Jan 18 2019, 06:22 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Car = '74 2.0 Liter, Dual Dellorto Carbs
For years I have been 'adequately" running an 009 mechanical only distributor. Finally took the pervasive advice out there to go with a vacuum advance dizzy from a 1.8L 914. Since only one of my Dellorto carbs had an existing vacuum port (ported type), I had to drill a port in my other one (no problem there). I used good quality anti-pulse valves in the lines and measured a maximum vacuum of 12 inches of mercury with partial throttle. Installed the 1.8 dizzy and set the timing, first without the vacuum lines attached. To satisfy my usual 30-32 degrees at 3500 RPM, the idle timing had to be at about 5-6 degrees (quite low for my setup which is happier at about 10 degrees. When I attached the vacuum lines my timing at 3500 RPM went sky high into the 40s. This seems way too high. Is this normal? Overall, I found the car to run better without the vacuum attached and the carbs plugged off. Am I doing something wrong here? I don't like the numbers I am getting. Everyone said this was the way to go with carbs, but I am not seeing results. Advice appreciated. Ansbacher |
BK911 |
Jan 19 2019, 08:17 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
I've been running an 009 with carbs on a 1.7 for over 10 years now.
Car runs awesome. If it ain't broke.......... |
Rand |
Jan 28 2019, 02:16 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I've been running an 009 with carbs on a 1.7 for over 10 years now. Car runs awesome. If it ain't broke.......... I love that yours runs awesome. But can you imagine a tuning that would bring another 20hp with the same mileage? I bet Joe Sharp could. Back on topic, should he use vacuum advance or retard? I found it to be differential because of difference years, dizzyy's, etc. I had one experience where the retard wasn't working and it made my idle high. Fixed with a part replacement. Carbs will be always suck when you get out of your optimum altitude. FI adjusts as needed. Is there really a need to keep debating it? . |
72hardtop |
Jan 28 2019, 08:52 PM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
I've been running an 009 with carbs on a 1.7 for over 10 years now. Car runs awesome. If it ain't broke.......... I love that yours runs awesome. But can you imagine a tuning that would bring another 20hp with the same mileage? I bet Joe Sharp could. Back on topic, should he use vacuum advance or retard? I found it to be differential because of difference years, dizzyy's, etc. I had one experience where the retard wasn't working and it made my idle high. Fixed with a part replacement. Carbs will be always suck when you get out of your optimum altitude. FI adjusts as needed. Is there really a need to keep debating it? . Not a debate with an EFI system. But unless one is traveling between altitudes on a regular basis (most aren't). I prefer a dual set up. More horsepower. If one is going EFI go with a modern set up not the stock one. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:49 PM |
