Giving Up On Vacuum Advance |
Ansbacher |
Jan 18 2019, 06:22 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Car = '74 2.0 Liter, Dual Dellorto Carbs
For years I have been 'adequately" running an 009 mechanical only distributor. Finally took the pervasive advice out there to go with a vacuum advance dizzy from a 1.8L 914. Since only one of my Dellorto carbs had an existing vacuum port (ported type), I had to drill a port in my other one (no problem there). I used good quality anti-pulse valves in the lines and measured a maximum vacuum of 12 inches of mercury with partial throttle. Installed the 1.8 dizzy and set the timing, first without the vacuum lines attached. To satisfy my usual 30-32 degrees at 3500 RPM, the idle timing had to be at about 5-6 degrees (quite low for my setup which is happier at about 10 degrees. When I attached the vacuum lines my timing at 3500 RPM went sky high into the 40s. This seems way too high. Is this normal? Overall, I found the car to run better without the vacuum attached and the carbs plugged off. Am I doing something wrong here? I don't like the numbers I am getting. Everyone said this was the way to go with carbs, but I am not seeing results. Advice appreciated. Ansbacher |
Rand |
Jan 28 2019, 09:21 PM
Let me take this second to say that I respect Joe Sharp. And he sure as hell knows how to tune carbs.
Anything I said above that sounded like I hated carbs should be re-looked at from where I was coming from. JoeS actually offered get me a six running years ago. Thank you. The point of my post is not to stir anything up more than thought. I don't hate carb. It's just freaking obvious that FI is more efficient than carbs proven for decades. I LOVE the sound of carbs. I got no dog in the fight. It's just conversation. When those carb throttle bodies open full, we all go silent to listen. (IMG:style_emoticons/default/wub.gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 02:22 AM |
