Giving Up On Vacuum Advance |
Ansbacher |
Jan 18 2019, 06:22 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Car = '74 2.0 Liter, Dual Dellorto Carbs
For years I have been 'adequately" running an 009 mechanical only distributor. Finally took the pervasive advice out there to go with a vacuum advance dizzy from a 1.8L 914. Since only one of my Dellorto carbs had an existing vacuum port (ported type), I had to drill a port in my other one (no problem there). I used good quality anti-pulse valves in the lines and measured a maximum vacuum of 12 inches of mercury with partial throttle. Installed the 1.8 dizzy and set the timing, first without the vacuum lines attached. To satisfy my usual 30-32 degrees at 3500 RPM, the idle timing had to be at about 5-6 degrees (quite low for my setup which is happier at about 10 degrees. When I attached the vacuum lines my timing at 3500 RPM went sky high into the 40s. This seems way too high. Is this normal? Overall, I found the car to run better without the vacuum attached and the carbs plugged off. Am I doing something wrong here? I don't like the numbers I am getting. Everyone said this was the way to go with carbs, but I am not seeing results. Advice appreciated. Ansbacher |
72hardtop |
Jan 31 2019, 11:18 PM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
You can garner a lot from that thread with the first 20 pages alone.
Remember.... Get above 14:0 - 15:5 on the progression circuit and below it (14:0 - 15:5) when on the main jets. Ideally when under load/WOT... 12:5-13:2 or so. 14:0 -15:5 is the highest area for EGT's. Load = Throttle position No lean tune cruising with mechanical only distributors. |
tmessenger |
Feb 1 2019, 01:28 PM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
72hardtop
Sounds like we have very similar engine builds, mine is: Fat Performance built 2056 long block, 42x38 ported and polished heads, Fat 442 cam, 8.3 : 1 compression 4k miles on the build. I just bought this car 6 weeks ago so am just now starting with the carb tune. The current configuration I inherited : 40 IDF Webers, 32mm venturi's, 60 idle jets, 135 mains, F11 emulsion tubes, 175 air's, SVDA distributor with stock 2.0 heat exchanges and Triad muffler. I've just ordered an A/F gauge to start the process. Can you tell me how your finalized carbs jetting came out and your A/F readings? Could be useful to both of us to compare notes. Thanks, Tim You can garner a lot from that thread with the first 20 pages alone. Remember.... Get above 14:0 - 15:5 on the progression circuit and below it (14:0 - 15:5) when on the main jets. Ideally when under load/WOT... 12:5-13:2 or so. 14:0 -15:5 is the highest area for EGT's. Load = Throttle position No lean tune cruising with mechanical only distributors. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:53 PM |
