Oil cooler seals, Should I able to see the bottom one? |
jdamiano |
Jan 20 2019, 12:09 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
I just finished replacing my oil cooler seals. I can see the bottom one just a tiny bit. Did it fall out of position during reassembly or is that normal?
Mark Henry |
Jan 20 2019, 02:13 PM
Tiny crack looking square at it? or 1/8"+ gap?
Yes you can barely see it through a tiny crack. Bigger gap it either moved or you have the wrong thick T1 seals. The T4 only used the thin late "doghouse" stepped seals, the T1 used 3 different seal styles over the years. |
Mark Henry |
Jan 20 2019, 02:14 PM
BTW....You'll know right away when you start it. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 08:09 AM |
