jdamiano
Jan 20 2019, 12:09 PM
I just finished replacing my oil cooler seals. I can see the bottom one just a tiny bit. Did it fall out of position during reassembly or is that normal?
Mark Henry
Jan 20 2019, 02:13 PM
Tiny crack looking square at it? or 1/8"+ gap?
Yes you can barely see it through a tiny crack.
Bigger gap it either moved or you have the wrong thick T1 seals.
The T4 only used the thin late "doghouse" stepped seals, the T1 used 3 different seal styles over the years.
Mark Henry
Jan 20 2019, 02:14 PM
BTW....You'll know right away when you start it.
