late model heater blower motor pics needed, Can't find how the heater blower is mounted on drivers side. |
buck toenges |
Jan 20 2019, 07:57 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I have a late model heater blower motor that has both heater tubes exiting from one location. As compared to earlier heater blowers that was mounted to a frame that mounted onto the engine block and had two exits for the heater tubes the later model was tucked in under and in front of the relay board. How was the blower mounted? Anybody have any pictures. The pet katalog only shows the earlier model.
Thanks, Buck |
JeffBowlsby |
Jan 20 2019, 08:45 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
This is the late model fan, with the late late siamese splitter - typical set-ups only have a single hose to the drivers side. Bracket welded to chassis, rubber pad, strap around motor body.
Attached image(s) |
dr914@autoatlanta.com |
Jan 21 2019, 12:06 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Lo-Fi Version | Time is now: 20th May 2024 - 11:13 AM |
