Sub Woofer Installation, Tried to get better Audio without carving up the car |
ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! First, where should the speaker go???? Wow - no particle board - furniture grade ply! Peel back the Vinyl, careful! Counter sync for flush hidden finish Score the vinyl, perhaps we can STRETCH it! Heat gun and PULL, gently Look at that circle, no wood showing, barely a wrinkle! Add a screen Bolt that Micro SubWoofer in place What the Passenger will see Perfect Fit Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s) |
914forme |
Jan 24 2020, 12:24 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
@horrizontally-opposed Pete, I have picked a JL Audio sub to try in that area. My plan is to take lay some foil wrap into the area, and then work my way out with fiberglass, build a sealed enclosure, and it will be protected with one of the perforated Aluminum plate foot boards. I will be painting or anodizing it black, and adding traction tape over it, leaving the holes exposed. Most likely add a sound Matt of the back side to reduce the opportunity for the AL plate to vibrate. That would annoy the (IMG:style_emoticons/default/stromberg.gif) out of me.
The JL sub I picked at @BBRock suggestion requires ~0.35 cu.ft. for a sealed box. Ported would be a bit larger. I will most likely do a sealed, as ports tend to enhance certain frequencies, and since I don't just play one key of music, I do not need to tune the system. Tuned ports would be handy for Gregorian chant. |
horizontally-opposed |
Jan 24 2020, 01:44 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
@horrizontally-opposed Pete, I have picked a JL Audio sub to try in that area. My plan is to take lay some foil wrap into the area, and then work my way out with fiberglass, build a sealed enclosure, and it will be protected with one of the perforated Aluminum plate foot boards. I will be painting or anodizing it black, and adding traction tape over it, leaving the holes exposed. Most likely add a sound Matt of the back side to reduce the opportunity for the AL plate to vibrate. That would annoy the (IMG:style_emoticons/default/stromberg.gif) out of me. The JL sub I picked at @BBRock suggestion requires ~0.35 cu.ft. for a sealed box. Ported would be a bit larger. I will most likely do a sealed, as ports tend to enhance certain frequencies, and since I don't just play one key of music, I do not need to tune the system. Tuned ports would be handy for Gregorian chant. Sounds like a slick setup. I am planning to use a JL 5-channel amp to power a JL 3-speaker component system for the stock speaker pods and doors, with the possibility of rear "fill" tweeters in the targa bar and the fifth channel for a sub. Was "arming" my old Pioneer amp via a factory 914 defroster switch on the dash (found an old one at EASY), which lit up when you pulled it out to tell you the audio system was on, and then using AUX in to plumb by iPhone in with RCA cables. Worked really nicely, but may go to Bluetooth for the next iteration of this setup. Just need a place to put that sub. Have looked at some of the slim-line subs out there, but so many of them are powered. Would love to see what you come up with. And good point on the port tube. I may reference the size of the port tube in an old JBL bass tube I think I still have, and just go with that. Any bass setup is gonna improve on no bass setup, and I suspect JBL did some homework on the size of that tube vs the 8-inch subwoofer. My goal is to have "invisible" audio that actually sounds good, with the only clue that there's a system being 6.5s as the front of the doors. With 914Rubber's ABS plastic door card blanks, I've started to wonder if the 6.5s could be mounted behind the door cards with "perforated" basketweave vinyl over them...much like the early 928 speakers (see below). On black, you might not even notice the holes in the basketweave. Thoughts? Good idea? Terrible idea? (IMG:style_emoticons/default/unsure.gif) Attached image(s) |
Lo-Fi Version | Time is now: 6th May 2024 - 02:37 AM |
